Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Appearance & Detailing
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 04-06-2006, 03:00 PM   #1
evilbadz's Avatar
Trader Rating: 1
Send a message via AIM to evilbadz
Default LED Side Mirror Turn Signal Writeup v1
Ok, here is the writeup I've been promising for a while. I accidently deleted most of the detailed pictures but what I could get again easily is in the PDF. This writeup will probably change over time, I will post it again if it does.
You will need adobe acrobat or something similar to read the PDF file, it was the easiest way to format it and still not take a day of writing HTML. The writeup is a large file, approximatly 581kb. If you are on a 56k this could take a while to download!
You can get acrobat reader here .
The Writeup!
If you have any questions or would like to get the LED Kit from me to make this install a little easier, let me know
Enjoy!
__________________
Josh Ellis / evilbadz
www.diod.es
LED Turn Signals in Your Mirrors!
How to change the color of your halos!
Cream 1979 Corvette w/383 stroker and really bad gas mileage!
evilbadz is offline   Reply With Quote
Old 04-06-2006, 03:36 PM   #2
Brian2006's Avatar
Trader Rating: 42
Send a message via AIM to Brian2006
nice write up and install seems simple and easy thru that write up
__________________
Brian2006 is offline   Reply With Quote
Old 04-06-2006, 05:59 PM   #3
evilbadz's Avatar
Trader Rating: 1
Just added a little schematic for a simple LED circuit
__________________
www.diod.es
Old 04-06-2006, 07:09 PM   #4
Racafella13's Avatar
Trader Rating: 2
Send a message via AIM to Racafella13
how much for the kit, and any finished pictures?
Racafella13 is offline   Reply With Quote
Old 04-06-2006, 07:19 PM   #5
Trader Rating: 2
Looks like a great write up! Thanks!
kraaazymike is offline   Reply With Quote
Old 04-25-2006, 02:24 PM   #6
InfiniteReality's Avatar
Trader Rating: 2
Damn it, took MY idea!! Not really, you did it first so it's YOUR idea! Props to ya!!! Now when I do mine I'll have the concept on how to do it! Mine will slightly differ, one day I'll get around to doing it!
I wanna see some finished pics and even some video, if possible, please!!
__________________
2008 Chevrolet TrailBlazer SS
Replica 22s, Blue Gauges, Front/Rear KBee Coilovers, All Custom LED Lighting, IEATSRT8 Intake, tune, 700+ LEDs
2003 Silver/Charcoal Suzuki Hayabusa
Definitely not stock & 850+ LEDs
2006 Black/Black Honda CRF50
InfiniteReality is offline   Reply With Quote
Old 04-25-2006, 03:47 PM   #7
evilbadz's Avatar
Trader Rating: 1
I don't have any great video really, have a few pics.
One video is at
The other is at http://mindmod.com/photos/car/turn_signals/right.avi
A Picture (if you need more I can try to take some later):
__________________
www.diod.es
Old 04-25-2006, 04:08 PM   #8
Trader Rating: 2
Dude that's awesome!!! More pics please!!
__________________
Old 04-25-2006, 04:19 PM   #9
Roadhouse's Avatar
Trader Rating: 8
Very Nice!!
__________________
My FQuick Link
Roadhouse is offline   Reply With Quote
Old 04-25-2006, 10:26 PM   #10
JasonWW's Avatar
Trader Rating: 1
It occurs to me that the LEDs don't look properly aimed. Since the main point of this mod is for a car that is along side of you is now able to see your turn signals, because it is too far forward to see the rear and too close to see the front side blinking. It seems they would need to be aimed not to the rear of the car, but slightly outward at a 45* angle and maybe slightly up.
Does that make sense?
Or am I missing the point of these being purely cosmetic?
JasonWW is offline   Reply With Quote
Old 04-26-2006, 01:20 PM   #11
evilbadz's Avatar
Trader Rating: 1
While LEDs do have a narrow viewing angle for full intensity, they can be seen glowing from the side. This, and the glass they are going through also diffracts the light. You can see these blinking from beside the car, they just aren't as bright as from behind / on the side behind.
This should be obvious from http://mindmod.com/photos/car/turn_signals/right.avi
__________________
www.diod.es
Old 04-26-2006, 01:45 PM   #12
Trader Rating: 2
I'd agree, they would be more effective if aimed, but will work nonetheless. On our cars I'm not sure it'd even matter too much either way, they're just SWEET looking!!
__________________
Old 04-29-2006, 11:18 AM   #13
JasonWW's Avatar
Trader Rating: 1
I remembered an idea I had a while back. Put some kind of bright yellow light source behind the mirrored lens. When activated it would create a yellow glow around the mirror. You might not see it in the day, but it would look real cool at night.
Old 04-29-2006, 11:32 AM   #14
evilbadz's Avatar
Trader Rating: 1
Quote:
I thought about doing that as well, wouldn't be that hard. I'd probably just remove the mirror housing, spray the inside with a chrome spraypaint, then put LEDs facing towards the housing. That was just my idea on how I would do it though.
__________________
www.diod.es
Old 04-29-2006, 11:36 AM   #15
JasonWW's Avatar
Trader Rating: 1
I was thinking more simple, like just mount a 1157 bulb behind there. Then use a relay to power it.
If you really want wild, my other idea was to remove them and mount small cameras there or further forward on the car like the front side marker lights. Then mount 2 5" LCD's on both sides of the instrument cluster. Might not work on a camaro, though.
It would streamline the outside for a unique look and give you a greater field of vision. Dark window tint would no longer be a hinderence as well.
Old 04-29-2006, 11:41 AM   #16
evilbadz's Avatar
Trader Rating: 1
My only concern with the 1157 is the heat, which is why i didn't suggest it. Could work if done right though. The camera idea is simply badass however
__________________
www.diod.es
Old 04-29-2006, 11:43 AM   #17
JasonWW's Avatar
Trader Rating: 1
What heat? It would only be on for a couple of blinks now and then. Not enough time to generate any real heat.
And yea. The LCD's would have a real "cool" factor to them as well.
Old 01-22-2007, 05:14 AM   #18
FredoCamaro's Avatar
Trader Rating: 18
Has anyone tried these?
http://www.a1electric.com/mirrors.htm
__________________
96 Z28 Hard Top N/A
Who cares if a car is quick, if it doesn't look slick
FredoCamaro is offline   Reply With Quote
Old 01-22-2007, 06:56 AM   #19
JasonWW's Avatar
Trader Rating: 1
Quote:
Originally Posted by FredoCamaro
The obvious question is do they make them for our cars, and if so, how much do they cost?
__________________
Qoute from 99345hp "Hell yeah Jason, tear that thing apart."
I do unique mods for the hell of it, so don't question my reasons.
The 99 TA is now riding on airbags front and rear for only $335. More parts to be added later. Install Thread
Super Low Project (plus other links)
Old 01-22-2007, 07:19 AM   #20
Trader Rating: 18
I found this a while back on some online catalog. I typed in Camaro and a picture with that link popped up. And it was priced at something like $300 for the kit. I think they custom make it to your application but I never called to checked it out…
__________________
96 Z28 Hard Top N/A
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
