t-tops swap
t-tops swap
i have a set of new t-tops to replace the old scratched up ones on my TA. my question is, is it difficult to swap the cylinder locks from the current pair onto the new pair or is it even possible?
It's not too hard. After removing the plastic panel, look closely and you should see a small, thin clip that wraps around the lock cylinder. Remove that with some needle nose pliers. You should be able to figure it out from there.
