69 z28 emblem help
Old 05-06-2006, 01:14 AM
andypdbz's Avatar
Default 69 z28 emblem help
i just got these in but these have 3 points sticking out, i guess they went into the fender.... but i thought they were going to be flat.
anyone who has these, did they come this way? and if so how did you flaten out the surface?
i was thinking some clippers may do the job but then how would i smooth out the surface?
i'll post a pic of them up later?
Old 05-06-2006, 01:30 AM
unSStoppable's Avatar
i would say time to take out the dremel
Old 05-06-2006, 01:47 AM
6-SPD4ME's Avatar
I second that!
Old 05-06-2006, 01:52 AM
andypdbz's Avatar
thats what i figured, but now to borrow one...
Old 05-06-2006, 01:57 AM
andypdbz's Avatar
Old 05-06-2006, 02:08 AM
Couchman86's Avatar
Use a dremel or just grind them off flat on a grinding wheel.
Old 05-06-2006, 02:36 AM
Scotty-Z's Avatar
Yes, that's how they come. They're also not contoured to fit your fender correctly, so you'll have to re-bend them.
Clip off the points, then grind them flat. Put the emblems under a couple layers of soft cloth and use either a hammer (gently!) or a vice to flatten them. From there do some test fittings to see which areas have to be recurved to fit your fender. Took me about 3 hours in all. Good luck.
Old 05-06-2006, 08:39 AM
andypdbz's Avatar
ok, and i assume you can stick them on there with 3M tape?
what kind of 3M exactly? and where can i get it?
also how do i remove the current emblems?
Old 05-06-2006, 02:05 PM
andypdbz's Avatar
bump
Old 05-06-2006, 03:44 PM
SS4Luck's Avatar
look up how to remove molding and thats how you remove emblems, its just a little bit trickier...
Old 05-06-2006, 03:51 PM
RrCoX22's Avatar
where are you putting these? you can drill holes into your panel and then just use some epoxy to make sure it sticks well. or yes you can snip the mounting ends then grind them down to be flush with the rest of the emblem and use either 2-sided tape or epoxy as well.
Old 05-06-2006, 03:57 PM
ls1-ss's Avatar
Try using some fifhing line to peel them off, just cut a foot long section of line and slide it between the body and emblem, it should peel right off. You will have to use some sort of cleaner to get the rest of the adhesive off(not sure what though). After that you can use some 3m double sided tape and stick it on, but if you need to bend it be very very careful it will break very easy, trust me I learned the hard way.
Old 05-06-2006, 04:32 PM
andypdbz's Avatar
these will go on the fender in front of the wheel, getting a hockey stripe and im going to put that in the break.
as far as the fishing line to remove the emblem, do i need to heat the emblem and adhesive up with a hair dryer?
Old 05-06-2006, 05:08 PM
ls1-ss's Avatar
Yes, it should come off a little easier with a little heat
Quick Reply: 69 z28 emblem help
