Seat questions
Seat questions
Last night I pulled my seats to shampoo and vacuum the carpet. 99TA.
I proceeded to tighten all the bolts on the seat; some were loose by hand which surprised me.
2 questions.
1. The seat back still has 1" of play it where I can wiggle it abck and forth no matter what I tightened. Does any one else have this issue? Like could you go check your car during lunch and see?
2. The air connections. The driver's side loses the pump up air shortly after using the buttons, passenger side seems to keep it much longer. I always read to make sure all the connections are tight etc. The main pump is under the passenger seat btw. Anyway, any one have any other ideas as to why they lose air? My last resort is to pull the seat back and see just where the lines go, but how do you get the back off?
Thanks for any help.
2 questions.
My rear seat has a very small amount of play at the hinges. I never noticed it until I removed it last night. When i bolted it back in, it didn't move enough to notice it. I removed only the two bolts at the very bottom.
2 questions.
2 questions.
