Sponsored by: DashLynx
Another HID projector project.
Old 05-16-2006, 09:37 PM
Blade's Avatar
Default Another HID projector project.
Not finished yet, but I figure i'll post some work in progress pics. The halogen silverstar bulbs I have in there aren't even secured, just sitting there. I was just trying to get my rotational adjustments taken care of in the test shot.
Day 1 pics:
Me slicing and dicing with a dremel to get the TSX projectors on.
TEST SHOT. This is a work in progress. I still need to adjust the aiming/rotation among other things. Although they came out much better than expected in this test.
Picture of the color change effect with silverstars.
Excuse the angle here, I was trying to get a good pic of the color change from an oncoming traffic aspect.
All in all, I got a lot done in day one.
Day two will consist of painting the projectors and housings with some high temp black paint. Perhaps I can get my final adjustments done as well.
Projectors are Acura TSX projectors, and the bulbs I used were silverstars. I have some Phillips 4300K HIDs on order.
Old 05-16-2006, 09:44 PM
01RedT/A's Avatar
silverstars? as in halogen silverstars? how does that work? either way good job getting into the hid world!! after doing two retros on trans ams ive realized this is more of a safety upgrade than anything else. anyone who has driven a t/a at night over 65 should know that its a game of russian roulette. Post more pics when your done!!!
Old 05-16-2006, 09:48 PM
Blade's Avatar
I used the 9005 bulb from the brights side for the test shot. I just sat it in there, not secured or anything, which explains the funny beam pattern.
I agree. The stock Camaro lights sucks as well.
Old 05-16-2006, 10:30 PM
The Black Pearl's Avatar
Could you make a writeup on this? I wouldnt mind having some bright headlights myself..
Old 05-16-2006, 10:42 PM
Blade's Avatar
That's the plan.
Old 05-16-2006, 11:22 PM
NxLS1496's Avatar
Originally Posted by Blade
That's the plan.
that would be the best idea ever!!
especially for us not so mechanically inclined people who need directions for mostly everything.......
Old 05-17-2006, 01:33 AM
Blade's Avatar
It's fairly involved, but i'll do my best to make it simple and easy to understand when I write it up.
Old 05-17-2006, 01:48 AM
Z28-CTYHNTR's Avatar
Ill go ahead and tag this for future reference.
Old 05-17-2006, 01:56 AM
Black98Z28's Avatar
write up write up write up! lol
Old 05-17-2006, 02:43 AM
Dabeztz28's Avatar
How much would you charge to make a pair?
Old 05-17-2006, 10:21 AM
Blade's Avatar
I really don't have the time to build multiple sets.
If you really want to know about someone making you a set, you should ask this man: https://ls1tech.com/forums/member.php?userid=21621
He's a sponsor on this site too.
Old 05-17-2006, 11:15 AM
DirtyBird222's Avatar
so much easier to do in a camaro than in a LT1 Bird! I had to send my housing fabrication project to a pro fabricator! I'm using Bosch E46 Projectors. I'm not worrying about high beams, since I have HID fogs too, and no inspections in FLA. I think I'm gonna switch my foglight color to 3000k and use 6000k for the headlights once all is said an done!
Old 05-17-2006, 05:08 PM
MrPongoSS's Avatar
I like that idea! Let me know how it comes out!
Old 05-18-2006, 09:38 AM
NxLS1496's Avatar
The e46's are in the bmw's right?
i think the 3000k in the fogs and the 6000k in the headlights would like good.
anyone know if you can fit a projector into halo headlights?
Old 05-18-2006, 10:36 AM
Hey blade how long are those TSX projectors? If they are smaller than the E46 projectors, I'll ditch those and pick some of those up lol. The E46 ones are bout 5 1/4 inches long. I won't have a problem, with fitments with these, I just have to cut some metal which I don't really want to do! And yes the E46 is from BMWs
Old 05-18-2006, 04:57 PM
Blade's Avatar
Diameter = 71.05mm
Height = 85.30mm
Width = 120.80mm
Length = 156.45mm
Length(seat of the lens to mounting holes) = 42.00mm
Length(mounting holes to end of bulb) = 96.95mm
Width(between top mounting holes) = 100.45mm
Width(between bottom mounting holes) = 103.45mm
Height(between mounting holes) = 41.50mm
from hidplanet
Old 05-18-2006, 05:00 PM
Blade's Avatar
Finished!
And oh man did I cut it close, but the cover plastic cover when on without touching. It's OK for my first time. I'll post pics when everything is dried up. I deviated from the whistler method a little bit when painting because I wanted my brights to work just how they did before.
Old 05-18-2006, 07:37 PM
SOULPOWER's Avatar
Its cool to see that more people is getting into the HID world!!!
i went with the vette C6 HID projectos, and they fit perfect on the camaro, and i friend of mine, put 4 low HID c6 projectors in his halo headlights and looks pretty cool to!
i'll post some pics of my friend later!
good job btw!
Old 05-18-2006, 09:25 PM
Blade's Avatar
good job btw!
Where did your friend get the C6 projectors?
Old 05-18-2006, 09:30 PM
SOULPOWER's Avatar
well the car on the pic, is my car with the C6 projectors
and my friend and i, we both get them from a guy at GM...
if you r intrested in one set, or some one else, send me a PM
Quick Reply: Another HID projector project.
