You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
ok i have a new 2006 trailblazer ss and i had been going out of town the past three weekends and there were a ridiculous amount of bugs all over the front end and i washed the truck last and it seems that the bug splatter made stains all over the front end ......what should i do?
for real though, i would do some serious scrubbing with good ole soap and water, then use stoner tarminator (http://www.tarminator.com/) - available at wal-mart, etc... anything left might be loosened well enough for a claybar.
I've found that using a quick detailer between waxes really helps prevent them from becoming a problem. It keeps the surface slick and protected, so bugs become more of a wipe off than a scrub off. Remember, it doesn't take long at all for bird poop to etch, so when it happens, act fast.
WTF!!! are all those guys posting on that thing 12 years old?? there gramar and spelling was horrible. i couldnt even understand what the **** they were talking about half the time.
Most bug and tar removers also remove wax, so I would at least recommend re-waxing the area. QD sprays do an excellent job of "refreshing" an existing wax/sealant, but are a poor substitute for applying a good layer of wax/sealant.
on some tough bugs that i have gotten on my car (usually the ones hit at ludacris speed) that give me a hard time, i have found that goo gone gel worlks awesome. it does however, like the bug and tar remover take off wax, so go back over the area when your done.
__________________ '01 T/A, Z06 wheels, WS6 high-rise airbox, SLP lid, K&N Filter, !CAGS, Rear O2 delete, Short shifter, SLP H.O. hood, Custom Bi-Xenon Projection Headlamps, LED Sidemarkers, Comp Cam 216/220@.050 .525 .535 LIFT, ZO6 springs, Pacesetter longtubes, 3 inch true dual exhaust with x pipe and Force Automotive mufflers, Dynolab numbers: 376.8 HP, 364.0 Ft-Lbs.
