PLz some directions on useing zaino!!!!
ok i have a black trans am with some swirls and scratchs. im gonna go ahead and get zaino. so can someone explain exactly how to use it and what to use. z-pc,zfx,z1,z2pro,z5....exc...
For every ounce of the polish put 4 or 5 drops in. The containers that come with the kit are 2 ounce so half filled = 4 or 5 drops if you fill it all the way then don't use more than 10 drops. Apply with an applicator pad or clotch in back and forth motions (directions say don't do swirls) Let dry for at least 30 minutes (longer it drys the better) and whipe off with 100% cloth. Go back again with microfiber towels if you have some.
It's just like using another other product line for a full detail:
- wash thoroughly
- clay as necessary
- wash/rinse
- polish as necessary (ZPC Fusion)
- wax/seal (Z5 or Z2 Pro with 4 drops of ZFX added)
One ounce of Zaino should give you 2-3 complete coats on your Trans Am. Apply it very thinly.
- wash thoroughly
- clay as necessary
- wash/rinse
do i use the ZFX with z5 or only z2 and if i use z5 do i use it in this order... the ZPC then z5 then z2 over z5 from then on, and also i guess being i need thin coats its not very good for puttin on with a buffer
For the first application, ZFX is recommended with either Z5 or Z2 Pro. After that, it's only need for mulitple coats at once.
Zaino also recommends that the final coat be Z2 Pro because of it's higher optical properties.
