Removing Fog Lights on T/A
There is 3 or 4 push pin tabs that hold the part of the bumper that sweeps up before the air dam underneath. You have to pull those out and bend that part of the bumper down, the foglight brackets are held in by 2 10mm screws then the whole assembly comes out. I ended up just replacing mine with some from Autozone since mine were all fogged up, I just adapted the brackets that came with the new ones to attach to the stock brackets.
One thing to add, when you see the foglights, take the connector loose before you start taking the ligh bracket off
On my 02 the wires weren't long enough to extend below the plastic, and I couldn't get both arms in there to hold the light to be able to undo the connector
