Wetsanding, how do you do it?
Well it looks like the nose of the car is going to need more than just some polish, the clear is looking pretty bad, so I'm wondering if a little wetsanding will bring it back
Problem is I don't know how (other than the obvious soapy water and fine grit paper)
So does anyone have any tips, tricks, advice, dos or don'ts, favorite products, stuff to stay away from
All suggestions appreciated
TIA
TIA
Shirley Temple Drinker
Keep your fingers together, or better yet use a block. Dont web your fingers out, as this will make the pressure different in differant areas. Use like a 3x3 section of 2000 grit, and keep it WET!
also dont use less than 2000 grit if your using a porter cable. may cause unrecoverable swirls unless you go to a rotary or something more. this was after keying the car, filling it with touch up, sanding it down then polishing. the key marks went away but i didnt do it right and did something to the paint.
http://i9.photobucket.com/albums/a74...2467resize.jpg
http://i9.photobucket.com/albums/a74...2470resize.jpg light two passes with ssr 2.5 w/ yellow pad
still looks swirled in the flash. probably from using 1500 grit or rubbing too hard
dont worry though she is all better now
http://i9.photobucket.com/albums/a74...3094resize.jpg
Use 2000 grit with soapy water or a little detailing spray mixed in. This will provide a slicker surface and is especially helpful if this is the first time you've ever wetsanded. Also, go back and forth in small, light strokes, not in a circular stroke. Check progess often by rinsing and drying the area. When it's flat move onto the next area. Rougher grit can be used by not recommended if this is your first time. I like to have my wife stand beside me with a hose and keep a steady light stream of water going over the surface. This rinses away all sanding residue immediately.
Wash the area real well. sand with 2,000 grit wrapped with small foam block. Have a sponge soaked with soap and water that you can squeeze above the work area while you sand insuring you wont work any debris into the clear coat. Dont sand in just one direction, be sure to use a X pattern. Sand a small area then rinse off and dry real quick checking your work. Once it is completely sanded move onto the next area. After everything is sanded begin buffing out with rubbing compound and working your way up to a fine polish.
What compounds/polishes have you used trying to fix the problem?
Originally Posted by ZaneO
What exactly is going on with the clear to make you think it needs sanding? Picture?
good question. just because wet sanding CAN fix it, doesn't mean it is the best way to do it.
You should always start with the least aggressive method, and then move up as needed, and there are several steps to try prior to wet sanding. including a DA and a rotary.
I would say take a couple of good pics, in the sun, straight on, and post them up .. let some of us look at them prior to wet sanding.
Mike is correct .., if it really looks that bad, repaint is aout the only hope.
A rotary, cutting pad and some Meg's diamond cut would be were I would start (after claying,prep, etc), but it sure won't do anything for divots like that ..
My first thought when I saw that pic was Wow, I have never seen an f-body with a fleckstone bumper before.
They aren't divots, they are more like etching in the clear, as if some type of acidic substance has been sprayed on it
I'll probably go ahead and try to wet sand the etching out, I've already been given a quote to reclear the front ($200 doesn't sound too much to me)
Once the camera gets recharged (had to get a new SDcard, the other got f*cked up somehow) I'll post a pic of what mine actually looks like
I bet your nose looks just like my black T/A...I'm going to have it looked at soon by a pro to see if it can be worked out, or if it's going to need spray. Mine looks like the pic above, but not quite as bad...I'll try to get a shot tomorrow.
I tried 3M's rubbing compounds on an orange pad with PC, and it didn't touch it either.
