Sponsored by: DashLynx
VHT Nite-Shades gone wrong...
Old 06-03-2006, 10:32 AM
Louie83's Avatar
Default VHT Nite-Shades gone wrong...
I VHT'd my corners and 3rd brake light.
The two rear corners turned out great.
The front orange ones and the third brake light looked almost flat black...
I wetsanded as much of the tint off as I could and am going to try again. Suggesttions for making them come out better?
Old 06-03-2006, 10:38 AM
Arachnotron's Avatar
You need to clear coat them.
Old 06-03-2006, 10:39 AM
911ss's Avatar
i got some friends that did it to their tail lights and the more clear coat the better it looks....
Old 06-03-2006, 10:50 AM
Louie83's Avatar
Sounds easy enough...
I actually sort of looked for some the other day while I was at the auto parts store. The only kind of clear they had also was a lacquer thinner. The guy there said it might be harmful to the plastic and advised me not to get it.
Any suggestions on where and what kind of clear to get?
Old 06-03-2006, 10:54 AM
http://www.corrado-club.ca/mods/tailtints.html
http://www.ls1gto.com/forums/showthread.php?t=36684
Here are a few posts on the subject that may help.
Old 06-03-2006, 10:59 AM
911ss's Avatar
ive heard of some bad things happening after a while of having it on the lenses. ive read of a few people's tail lights actually becoming warped and cracking after using this product for a while. it does look good though
Old 06-04-2006, 08:46 PM
Louie83's Avatar
They're looking good now (a little too dark....oh well).
Thanks guys.
Old 06-04-2006, 09:44 PM
THE CHOP SHOP's Avatar
If you want to strip the nightshades off you can try Brake fluid. I have used it before to remove paint from a lexan R/C car body. I left the body in the brake fluid a little to long and got a haze but if you are removing the nightshades from the lights you could buff the plastic back because it is not as agressive as laquer thinner. I used laquer thinner on my third brake light because i was so pissed i did not care. It removed layers of plastic but i was able to wet sand it smooth. Try the brake fluid on one if you think they are to dark and want lighter and see how it goes. I bought a cheap bottle from advance and just poured it into a container and left the part in over night. Of course cleaning it very well before paint is a must.
Quick Reply: VHT Nite-Shades gone wrong...
