CME guys, just some questions
Mine is on the way and I just had a couple questions:
1. How much did you pay to have the valence painted? (and was it done cheaper by a friend or did you pay in full for it at a shop?)
2. Did you put it on yourself (if it wasn't on your car stock) or have a shop do it for you? If so, how much did they charge you to install it?
3. Where all did you apply the tape to put the valence on the bumper? I might use tape and some emblem adhesive or glue on the back underside as well, but just wanted your thoughts on the best placement of it visually and structurally.
4. Do you have your tips coated in anything? I'm considering having mine coated in a clear powdercoat. How does yours work?
Thanks for any help you can provide.
1) 150 bucks! I had another shop tell me 100, but when I told them what colar I needed, they responded with "chevy black". So I paid a little more to get the right color of black.
2) I put mine on myself
3) The tape go's around the entire valance, also uses 3 pine fasteners.
4) Nothing on my tips yet, I want to get them chromed.
A little tip on the tape, put the tape on before you have the valance painted. I wish I would of!
Where did you find your setup?
I have only found one place that carries them so far, and still has some in stock.
Did I get that right? I would think that having paint and clearcoat over the tape might make it hard to get the backing off.
Yes, thats right. If you dont, like I didnt, you will see the tape. It buged the heck out of me. I ended up getting some black seam sealer and filled it in. Looks better than seeing that tape.
I would not recommend painting and clearcoating over the tape, it would most likely chip or flake when you installed the valance as you must press it firmly against the bumper when installing to get the tape to stick properly. Plus what if you wanted/needed to remove the valance later, you would risk more paint damage. Noty a good idea in my book.
The secret to having the edge of the tape "dissapear" when installed is to simply install the tape to the valance and before attaching to your rear bumper just take a black "Sharpie" marker and color the top edge of the tape. It really is that simple and costs nothing to do.
When I had mine I didn't use the tape they supplied... I went to a paint shop & bought some 3M black acrylic tape... It's the same width as the stuff supplied, but it's not as thick & is a hell of alot stickier... Using this stuff I couldn't see any of the tape after install... Also I recommend using some 3M addhesive promoter on the valance before laying the tape... You'll see a little ridge line on the valance & that's where you want the bottom of your tape to be... You should have a little over a 1/4 inch gap between the top off the valance & tape.... I also hung the valance with the retainers first & then proceeded with fitting the valnce a section at a time... It kinda acted like a guide with it hung by the retainers... On my tips, I smoothed them & painted them black while leaving the lips polished... Good luck with it & take your time!
-Mike
-Mike
I might see if I can get a pewter touch-up paint pen to do on the top edge of the tape. Hopefully that will work well, because if I use a sharpie, you'll still see it since my car is pewter.
How much did you guys pay to have your valences painted?
my valence was 150 for paint, and autozone sells gm reproduction paint pens that work FANTASTIC!!!! i would use one of those to match the 3m stuff, also, i used automotive goop to secure my valence, it holds 100000x stronger than the 3m stuff, dries clear and doesnt damage the paint, plus you get the closest bond for the valence and the car leaving no gap what-so-ever. if your interested in this method, autozone sells it as well, and its only like 5.00.
what i did was, connect the pin things that are on the car, so it holds itself up, then i took a jack and jacked the valence up till it was as flush as possible to the car. I then went under the car with the goop and glued the **** out of the valence, let it set for about 2 hours on an 80 degree day, and it was good to go. the best thing is, the glue is very rubbery so if you need to take it off it will not damage your paint.
good luck!
good luck!
Yes, thats works for us with the black cars, but his isnt. If the painter puts a light coat of base color, he wont have a problem. I might be wrong
Anyone know where to get the rear 2 gold hanger brackets for the Dual/Dual? I tried calling SLP about them and they said that it should be a GM part.
I told them: "I wouldn't think so, seeing as it was your exhaust and you guys modified the SS for GM. Plus you sell them along with your Dual/Dual/Powerflo exhaust systems." He told me that SLP simply used the stock hangers on the rear of the SS's to mount it and that it was a GM part. Well, I tried two GM dealerships and neither of them had the part... because obviously GM never made the Dual/Dual catback! I asked why GM would have the part if it was SLP that put the catback on and used their own aftermarket exhaust.
I guess I need to call SLP back and just ram it through their thick skulls that they do indeed have the part I'm looking for?
You could probably see if you can get the stock hangers since SLP catbacks use the stock hanger locations. Either that or get a muffler shop to fab some up for you. Pretty sure that's the easiest way.
