Quick LED question.
Quick LED question.
I'm gonna replace the taillights, DRL's, and signals with LED's in my Camaro. I should use the colored LED's (red and amber) correct ?
you can use red or amber, but if the lenses are already tinted those colors, then there would be no need. you could get white and it would give you a more uniform look since leds from different batches can have different hues to them. if your lenses in those areas are clear, then definately use the colored, and dont get then second hand if they cant assure you that they are all from the same batch. good luck and be sure to post up pics!!!
