Help with PIAA 1100x Install
Old 08-15-2006, 06:16 PM
sirhavoc's Avatar
Default Help with PIAA 1100x Install
I just got my new piaa lights in today and i have a fwe questions. 1. do i have to tap into the stock foglight wiring before or after the piaa pl5fb relay or before? and also i dont see how to mod the stock foglight mounts to make the neww piaa light mount. any help would be greatly appreciated. Thanks
Old 08-15-2006, 11:52 PM
sirhavoc's Avatar
ttt any one?
Old 08-16-2006, 12:17 AM
Tainted's Avatar
free bump for you
Old 08-16-2006, 07:38 AM
drivefast4fun's Avatar
ok, I have the same lights on my car, and I took the three wires (one open, the other two go to the piaa switch) and brought them into the car. I have the switch routed up under the ashtray, and I took the single wire that is your source wire, and just T-tapped it into the switch wire under the dash, so they will work like factory. Then you dont have to cut any of your factory lighting or wiring. On the other end, I just took two burnt out bulbs, broke the glass off of them, and filled that with silicone to keep water out, and plugged them into the sockets and zip tied them out of the way. not sure on the mounting
Quick Reply: Help with PIAA 1100x Install
