Can a Trans Am and Camaro Gage cluster be interchanged??
Old 08-18-2006, 10:19 AM
DogNutz's Avatar
Default Can a Trans Am and Camaro Gage cluster be interchanged??
As stated, are they the same shaped so that they could be swapped from a 99 Trans Am into a V-6 99 camaro? I would love to keep my 155 speedo and such.
Old 08-18-2006, 10:23 AM
Luna's Avatar
i am almost positive it will FIT. But I'm not sure if they are interchangeable between the LS1s and the V6's
Old 08-18-2006, 10:27 AM
DogNutz's Avatar
I am swapping my whole drivetrain into said v-6 car and of course the wiring harness/cpu if that helps with further info. From the ground up the camaro has ALL SS PARTS It basically is a SS with a v-6.
Old 08-18-2006, 10:50 AM
ZFan88's Avatar
Why would it not work then if you're swapping everything over. Pretty sure it fits, measure it if you're worried
Old 08-18-2006, 11:01 AM
DogNutz's Avatar
I dont have it down here yet to measure it. It is still at my cousins house in kc where i parked it after i bought it because i couldnt drive 2 cars home to columbia.
Old 08-18-2006, 11:05 AM
DirtyBird222's Avatar
I swapped a camaro cluster into a trans am so I'm sure it would work. Just make sure you have all the right bulbs and don't have an Uh oh like me and get half your gauges red and half blue
Old 08-18-2006, 11:20 AM
hotrod_bljak's Avatar
That sucks. Well, least you got everything fixed right.
Old 08-18-2006, 11:23 AM
DogNutz's Avatar
Where would i get blue bulbs to replace the red ones in my transams gages?
Old 08-18-2006, 11:37 AM
can't do it with trans am gauges, only camaro ones. I switched to the camaro because I absolutely hated the trans am gauges in the day with the ugly yellow needles and **** Camaro ones are little bit cleaner looking and i still have my T/A bezel!
Old 08-18-2006, 11:40 AM
There's got to be a way that you can change the bulbs in the T/A's. I am sure someone has done it.
Old 08-18-2006, 11:50 AM
00firebird's Avatar
yeah there is, you can rip off the red film on the back i believe and then put any bulb you want.
Quick Reply: Can a Trans Am and Camaro Gage cluster be interchanged??
