clear sidemarker question
i got some clear sidemarkers. the bulb on the driver side keeps blowing bc precipitation keeps getting in there. it is getting in there bc the bulb got hot and melted/disformed the hole where the bigger bulb goes in. how do you guys think a led bulb would work in there? can a led bulb blow bc of being wet?
ANY kind of electronics and water do NOT mix.....even LED's are subjected to mositure at the base where the anode and the cathode make a connection to the socket itself.
are u sure its moisture... i was having the same problem and there was actually a little piece of plastic that was in the socket, it was preventing the contacts to fully touch and i blew 3 or 4 bulbs before i aked the same questin...
I dont have clear corners, but for a lil' while, every time I washed my car, I would blow atleast 3 lights before the moister would go away. I reinstelled the light housing, and made sure it was super tight, and have not had the issue since (knock on wood) I guess it is a problem with a lot of the 4th gen camaros.
