Some Motor and Interior Shots Of The T/A
Sorry no before pic
Motor.. i washed it and detailed it. Here was my process. washed the motor by hand first to get rid of some dirt and grime. Then took it to the car wash and sprayed with the engine/tire degreaser let it soak then sprayed it off.. took it home toweled dried it off.. i had really no deatiler. so i put tiny bit of meguiars NXT interior cleaner on the black.. Well here is the motor
Now here is the interior shots. nothing special at all.. Btw shifter is Pro 5.0 and i cut the pro 5.0 stick 1.5" and it wrapped with the 'HURST' ****
<----- NEUTRAL
<---- 1st Gear
well what do you think??
<----- NEUTRAL
<---- 1st Gear
Originally Posted by 5550racing
I wouldn't wash it too often. Knock sensors are a pita to replace...
and yea i know about the knock sensors, or i know of them.. what are they? where are they? what is their purpose??
They're these.
They go in those 2 holes under the intake. See the one torwards the front, you can see in the aluminum where the water sat, and seeped into the hole. It just rusts the sensors away after time.
oh, It's not in the picture but there's a wire running to each with a rubber thing that plugs into them.
You can search for what they do.
Originally Posted by TORCHD 02 TA
wow that sux.. hopefully it will be ok.. i did run it for some time.. hopefully the heat will evaporate it
Yeah I though It would evaporate too. But there was still water standing in them when I took it apart. I'm still going to wash my motor. I think I water proofed the sensors. Back on topic! motor looks clean.
hwo did you water proof them? and thanks for the compliments
Originally Posted by LS1MONSTER
Damn your engine came out great!... The QTP sticker really takes away from it though.
ehhh i jsut out their LTs on and saw the sticker in my center counsel thought i would throw it on..
Nice engine bay, but I agree with removing the QTP sticker. Really distracts from the rest of the clean bay. I've washed my motor dozens of times and no problems with the knock sensors. You just have to use some common sense and not apply high pressure or I don't even use a regular hose's pressure, just a slight mist. I then blow it dry with a leaf blower. No problems and I've been washing mine since 2001.
Bryan
parbreak
Bryan
parbreak
