New SS emblems?
I don't see why not. Just cut the adhesive to fit the emblem and you should be good to go.
Just so you know, when I removed my sotck ones to replace them with the stainless ones, I was only able to 'save' 1 set. The emblems aren't a flexable urythane they are actually quite stiff. At any rate, be super-dooper careful when you remove them or you'll end up with shattered dreams. Good luck.
LS1Tech Co-Founder
That is dumb to re-use them, especially with any double-sided tape. They won't sit as flat as they did, and are probably tweaked from being removed. Just buy new ones, they aren't that expensive.
You can sell the used one to some Z28 poser that wants SS emblems to help recover some of the cost
