Sponsored by: DashLynx
Claybar HELP
Old 10-15-2006, 10:55 AM
Gluemaker's Avatar
Default Claybar HELP
Ok, I used this claybar yesterday and everything was fine. I go to use it on my bcar and the dang thing is falling apart. Its crumbling and its sticky. We ran out of the detailing spray so we have been using carwash soap and water. What can I do to get te thing hard again? I neeed to figure this out since I've already done my hood and the car has been washed with dawn soap.
Old 10-15-2006, 10:58 AM
michaelg589's Avatar
your mistake was using soap and water instead of the detailer spray. The soap dried out the clay bar. Go get another kit.
Old 10-15-2006, 10:59 AM
You wash your car with dish soap?!?!
Old 10-15-2006, 11:15 AM
Spd-Kilz's Avatar
It strips all the wax off the car, and gets it right down to the clear coat, so it's easier to use the clay bar. That's the only time you ever even think of using dish soap.
Old 10-15-2006, 11:22 AM
DANSBIRD's Avatar
Old 10-15-2006, 12:04 PM
CashMoney's Avatar
I use soap and water all the time and have never had a problem. **** I'll use the bar up to 3 or 4 times depending on how bad the car is. What brand of claybar is it?
Old 10-15-2006, 01:09 PM
Avengeance's Avatar
The problem is the Dawn soap... its eating up the clay bar, its a very aggresive soap vs car soaps. Had you used regular car soap for the water/soap used with the bar it wouldnt have happened. Buy a new bar.
*edit*
I just reread your post.. did you use Dawn and water for the clay lube? If not what kind of car wash soap did you use?
Old 10-15-2006, 04:01 PM
Gluemaker's Avatar
I washed the car in dawn soap, and for the clay lube I used meguires nxt soap and water. It was a mothers clay bar.
Old 10-15-2006, 04:22 PM
Gipraw's Avatar
Get another clay bar . and use a quick detailing spray as a lube .. Mother's Meg's and Poor Boys all make QD's that function very well as clay lube.
I am not a fan of using car soap (or any other kind of soap) as clay lube .. The only benefit of using car soap as a lube is that it is cheaper than QD, and unless you are claying your car once a week, don't be cheap, spend the extra 7 bucks and get enough QD spray to get the job done ..
soap will cause clay bars to break down, but haven't seen car soap do it that quick before .. usually takes more than one or two applications .
any chance the bar froze, or was left soaking in the soapy water ?
As for washing with Dawn, not a fan of that at all .. once in a blue moon will probably not cause any long term damage .. but why take a chance? It is hard on the car's paint, and hard on the plastics and rubbers on your car also, but that is a discussion for another time and another thread ..
Old 10-15-2006, 09:41 PM
TP121's Avatar
If you are gonna use soap, use Ivory.
It won't eat the claybar.
Old 10-15-2006, 09:53 PM
SRfastZ's Avatar
your not suppose to use dawn soap to wash your car all the times just for lube when using a clay bar.
Old 10-16-2006, 12:55 AM
spy2520's Avatar
when i claybar if i run out of lube i just use a whole shitload of water, damn near constantly...
Old 10-16-2006, 02:09 AM
Avengeance's Avatar
NXT and water should not have eaten the clay bar.
Old 10-16-2006, 05:48 AM
Rowdy94's Avatar
yea something else ruined it...not the soap and water. zaino's directions say to use their car wash diluted with water.
Old 10-16-2006, 08:23 AM
Gipraw's Avatar
you should NEVER use Dawn as a clay lube .. never.
Old 10-16-2006, 08:39 AM
FirehawkNS's Avatar
hasn't done anything to my bar since NXT came out.
Old 10-16-2006, 08:51 AM
Gluemaker's Avatar
I justed used to dawn soap to wash the car to get the wax off it. A few weeks back I put two coats of wax on her so I really needed to get that off. The bar was in my house on a a piece of cardboard. I don't know what happened. When I started it was fine. By the end of doing the hood it started to break down. So I got my hood done. Its smooth as can be. Looks amazing. This weekend I will start over. I through 1 coat of NXT wax on the car just to hold over till the weekend.
Quick Reply: Claybar HELP
