Sponsored by: DashLynx
old gum...
Old 11-29-2006, 12:52 PM
1SicV8's Avatar
Default old gum...
whats the best way to get gum off a car....i have some gum that looks to have been on my daily driver for a long long time...its pretty hard...how can i remove it
Old 11-29-2006, 01:09 PM
2000LS1TA's Avatar
try going to the car wash and use when of those high pressure, pressure washers. Should do the trick, good luck
Old 11-29-2006, 01:17 PM
unSStoppable's Avatar
Try to loosen it up with the good ol' thumbnail and some window cleaner (or wd40 or somehting along those lines). You could also take something with a flat edge liek a paint scraper, wrap it in an old t-shirt (so u dont scratch the **** out of the paint), and try that. Dont yell at me for that last solution either... it works on my DD Exploder EBE and ive never scratched it.
Old 11-29-2006, 03:01 PM
Brian2006's Avatar
Goo-gone
Old 11-29-2006, 03:30 PM
JoeyAnderson's Avatar
Goo Gone or Bug & Tar Remover.
Old 11-29-2006, 04:17 PM
Gipraw's Avatar
plastic razor blade and bug & tar remover .. put the remover on, let it set for a few minutes, then scrape off with the plastic razor blade ..
Old 11-29-2006, 10:58 PM
Trev_SS's Avatar
Originally Posted by Brian2006
Goo-gone
Old 11-29-2006, 11:17 PM
osvaldo's Avatar
clay bar wont do it?
Old 11-29-2006, 11:23 PM
dj2005's Avatar
Peanut Butter? Or is that only for tar?
Old 11-29-2006, 11:34 PM
bjamick's Avatar
well they make some stuff that you spray onto the gum and it freezes it and makes it hard as a rock then all you have to do is pull it off either with a scraper or hands gets the gum off the sidewalks at my work..
Old 11-30-2006, 12:37 AM
BLK_Z28's Avatar
Putty knife...
Old 11-30-2006, 02:31 AM
TUMBLRws6's Avatar
lick it
you might try a flat head screwdriver lol
i have no idea...but heres a bump
Old 11-30-2006, 10:47 AM
kny3twalker's Avatar
liquid nitrogen will freeze that gum, then it should just dissolve as you wipe it off.
Old 11-30-2006, 11:35 AM
01ls1lover's Avatar
Bug and tar remover fucken sucks.. Use 3M Adheisive romover Chris **** works good.
Old 11-30-2006, 05:37 PM
CashMoney's Avatar
Get it cold with an ice cube then price it off.
EDIT: You might need a few cubes of ice.
Old 12-03-2006, 06:11 PM
f50nut's Avatar
lacquer thinner dissolves it
Old 12-03-2006, 06:21 PM
Y2K Z28's Avatar
Doesnt that desolve paint too?
Old 12-03-2006, 06:24 PM
kevinclark09's Avatar
I don't think so, I used it to get the glue off of my car after I did the !molding mod and it didn't damage the paint.
Old 12-03-2006, 07:00 PM
Y2K Z28's Avatar
Probbaly just use it in small amounts.
Quick Reply: old gum...
