Halo and HID question
Okay, i havent been paying attention to the halos and HIDs until i just burnt out a silverstar. So...does the center light in the Halo just do the halo??? or does it shine like a third headlight AND do the halo thing? Because to me it looks like three actual bulbs, and then a halo. If its just a halo then no way.
HIDs...do they come with the entire headlight assembly too or is it just two bulbs and equipment.
Mainly i ask bc my stock headlights look like s#!t. Yellow... beyond repair, lol. And plus I've burnt a lowbeam out.
Thanks!
Thanks!
The HID's are basically just replacement bulbs that go in place of the stockers, but they come with a little box which contains the ballast and which you just velcro to the fender. Check some of the HID Headlight sponsors on the board. HID King is one of them I think?
Halos just use the stock bulbs, the Halo itself is just a LED. Once you turn your headlights on, you won't even see the Halo light up since the the headlights are way brighter. The "third bulb" behind the halo is really nothing, the light from the low beam shines through it. If anything, Halo headlights put out a bit less light due to the obstruction caused by the line that defines the Halo section. Don't get me wrong, I love mine, but don't expect improved lighting out of them.
Manny
Manny
If the low beam shares the halo hole then wouldnt it be brighter? I know that in spot lights the bulbs are a lot of the time the same, just the mirror part is bigger. For instance, theres a 2 million candle spotlight that uses an H1 bulb, and a 7 million candle deal that uses an H1 bulb too, one just has a huge reflector. Wouldnt this be the same concept for the halos?
here is a bad its a touch fuzzay pic of my halo at night, dont have headlights turned on just to give ya a visual
ill take a pic tonight of lows and brights on for ya if you like
If you want to get technical the halos will shine less light because of the obstruction in the middle of the low beams. Will you be able to tell the less light? Probably not.
HID's will just replace the stock bulbs unless you want to get into retrofitting and such.
-Nathan
-Nathan
well if by less light you mean much brighter then you are right. and the brights on these halos forget about it HELLA bright. bottom line. coming from someone who has had both. and did a comparison when switching them out. ~Guy
Are you sure you aren't talking about PROJECTOR Halos as opposed to the normal Halos?
Copy & Paste Moderator
Originally Posted by DEMONBIRD
That makes absolutely no friggin sense... How in the heck is a stock headlight LESS bright than a STOCK HEADLIGHT WITH A PIECE OF PLASTIC IN FRONT OF IT WITH A RING MOUNTED TO IT ?!?!
Interesting. Thanks for the replies. Anyone have HIDs and halos?
Yes, here is a thread with pics:
https://ls1tech.com/forums/appearance-detailing/684676-new-headlights-going-i-know-theres-billion-threads-lol.html
