best product to remove swirls without a buffer?
Restricted User - Non Spon Soliciting
what are some really good products I can use just by hand to get swirls out of my black paint. What process should I use in using these products? thanks
that said .. you are fighting an uphill battle.. if you are going to do it yourself, invest in a PC, and the proper pads and products to do it correctly.
check out this thread on using ScratchX
https://ls1tech.com/forums/appearance-detailing/519206-how-get-rid-swirls.html
Originally Posted by f50nut
Keep in mind that "swirl removers" are actually swirl fillers. The swirls are still there, just hidden.
Guest
Posts: n/a
Since he is doing it by hand, I dont think it would matter...You're not going to get swirls out by hand. However if you really want to know the process of going about getting swirls out...
G/C Wash x2
Clay Magic
G/C Wash
#83 x 2 rotary burgandy pad
#80 via rotary polishing pad
# 9 via PC Polishing Pad
G/C Wax x 2 via PC one and By Hand the other
Originally Posted by 317indy
G/C Wash x2
Clay Magic
G/C Wash
Clay Magic
G/C Wash
good process, just pretty agressive, and could be overkill in a lot of instances.
and you can remove some minor swirling by hand .. it just takes a LOT of work ..
http://meguiarsonline.com/forums/sho...threadid=14848
get some scratch x, get plenty of rest and give it hell. if i remeber correctly you use a "cross hatch" pattern. apply firmly in a x patern, then an up and down pattern. ur seriously gonna kick ur own *** doing it by hand but the outcome is very rewarding. good luck man. o yeah, wash the car first, then use a clay bar, then the scratch x, then apply a finisher like nxt wax, or #26 or gold class. or whatever u like. good luck! post up some b4 and after pics
I think the best product would be the local detailer that will do a polish job for you. Don't take it wrong, but if you are staring at a car full of swirl marks, and can't afford/justify the idea of dropping a few hundred bucks on a PC + supplies... the next best step is to pay someone who has the stuff to do it.
Otherwise you're gonna spend half the detailing charge, get poorer results, and use up a whole bunch of your time and energy.
Guest
Posts: n/a
Originally Posted by Gipraw
must be going after some pretty agressive swirls with that process..
Most people dont know how to detail their cars. Thats the usual process to get rid of marring, swirls, ect...
are you saying I don't know what I am doing because I am saying that is an aggressive approach?
Originally Posted by Kman
You are incorrect my friend. Meguiar's swirl removers remove the swirls and don't fill them in.
Guest
Posts: n/a
im saying i used to do this for a living, and every single car that I detailed, the owners of the car didnt know how to properly take care of their cars paint. so this was the usual process for me to do to a customers car.
I am saying that while the steps in your process are correct, the machine you are using and the products you have listed are pretty aggressive, and more times than not, would be way more than most people would need to be using.
All swirls are not the same, and they don't all need to be hit with a sledge hammer. Just because a rotary and #83 will fix it, that doesn't mean it is the best solution.
You always want to fix the defects with the least agressive method possible, for the long term health of the paint, and the process you stated is far from being the least agressive.
