Sponsored by: DashLynx
97-2002 Gauges Same On V8 Camaros
Old 12-08-2006, 12:37 PM
HIZPANICGUY21's Avatar
Default 97-2002 Gauges Same On V8 Camaros
Are 97 Z28 Gauges The Same As 98,99,00,01, And 02? Im Pretty Sure They Do But Im Not Certain..thanks For All The Help
Old 12-08-2006, 01:07 PM
The Black Pearl's Avatar
I believe they are.. They have the same 97's have the same dash as the 98+s..
Old 12-08-2006, 01:30 PM
ROCNDAV's Avatar
The 97/98 used analog signals directly from sensors where the 99+ received the signals (Digital) from the ECU. I don't know how or if this affects the electronics in the gauges, but the physical sizes and dimensions are the same between 97-02.
Old 12-08-2006, 08:22 PM
Koo..thanks Guys
Old 12-08-2006, 09:23 PM
WhiteStripes's Avatar
As far as sensors go, the ECU sends the coolant temp guage a dummy signal on the 99+ cars.
Old 12-08-2006, 10:34 PM
CULATR's Avatar
A DUMMY SIGNAL????? ok please more info on this!!! so the temp gauge is bascially false??
Old 12-09-2006, 02:30 AM
6LITEREATER's Avatar
Don't plug a 1998 cluster into any other year or vice versa... The result is smoke...
Old 12-09-2006, 03:31 AM
Z95m6's Avatar
The 97 cluster is a one off as well as it'll only work for LT1 cars. I've tried plugging a 98 firebird cluster into my car with a 97 dash and it would work but the gas gauge and temp gauge didn't work.
Old 12-09-2006, 10:00 AM
'Trust''s Avatar
Its not a dummy signal, it still gets it from the temp sensor. However on 99+ cars the temp change for the needle to move is much bigger than on 98. Basically the 99+ guage will tell you if your car is over heating or not.
Old 12-13-2006, 09:46 PM
CULATR's Avatar
so if its staying in the middle mostly when driving and no where past the middle thats a good thing right??
Old 12-14-2006, 06:40 PM
NufNuffZ28's Avatar
That is correct . It's not accurate as it is always in the middle even when the temp varies some. Overheating will still be signalled by a swift swept to the right.
Old 12-14-2006, 10:55 PM
CULATR's Avatar
Is there any way to make the temp guage work as the other years do???
Old 12-15-2006, 07:42 AM
RacerScott's Avatar
so your telling me that my temp guage in my 1998 ss is acually accurate
Quick Reply: 97-2002 Gauges Same On V8 Camaros
