Already have HIDs in headlights...which temp for fogs?
Old 12-13-2006, 08:35 PM
Blackbirdws6's Avatar
Default Already have HIDs in headlights...which temp for fogs?
I am currently running a 6500k (slight purple hue) Kaixen HID hi/low kit in the headlights that I am very happy with. I'm simply looking to go to HID's for the foglights and am a bit undecided on which color temp to go with. Should I match the headlight temp or go with a temp to match the white LED's (slightly blue tint) such as the 6k kits? Below is a pic of the current setup.
Thanks
-brian
Old 12-13-2006, 08:44 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Match the headlights.
Old 12-14-2006, 08:07 AM
_JB_'s Avatar
I second that.
Old 12-14-2006, 08:28 AM
That's what I was thinking. Thanks.
-Brian
Old 12-14-2006, 03:22 PM
DirtyBird222's Avatar
match them or go with 6000k. what foglight housings do you have btw?
Old 12-14-2006, 05:52 PM
LS1_SS's Avatar
I think a few different things would look great. A 3000K kit? a 6000K kit? or a 10000K kit. It would set both kits off if they were different, make the car stand out more!!
-Nathan
Old 12-14-2006, 09:46 PM
I'm running the optilux LED ring foglights that use H3 lamps (not pictured in sig). I've thought about going with a 6k kit but I just don't think it will look right.
Old 12-14-2006, 09:53 PM
3000k would be you best bet for offset and for performance lighting use, they are awesome for bad weather situations
Old 03-15-2007, 11:23 PM
96silverram's Avatar
I would either match the H4 with what you already have or go with a 4500 to 5000k H3 foglight to make it appear more white. I like the purplish color of the H4's maybe use more whitish light so you don't make a mis-match in color between the two setups.
I matched mine, 6000k H4's & 6000k H3's
Old 03-15-2007, 11:27 PM
1meantransam's Avatar
i say match them up, would look weird with 2 different light colors
Old 03-16-2007, 12:09 AM
muddmanWS6's Avatar
ive got 6K in both of mine and they are amazing. got them from nate on here.
Quick Reply: Already have HIDs in headlights...which temp for fogs?
