how do you remove rear seats?
Kleeborp the Moderator™
There is one bolt that holds the bottoms in place, and it is at the bottom of the front lip of the cushion, right in the middle. Once you get those out, it should be pretty easy to see the two bolts at the bottom corners of the seat back that hold that in. You'll just need to take those out, and remove the seat belt guides from the back.
wow i just finished putting my whole interior back in like 3 minutes ago so it's fresh in my mind. for the bottom part of the seat, there's a 13mm bolt that is located towards the center on the front of the seat.
for the back rest part, there's a 13mm nut on either side of it where it "pivots" down. if you want the back rest completely out, you're going to need a small torques bit to remove the belt guides.
Restricted User - Non Spon Soliciting
Originally Posted by DEMONBIRD
Looks like they've got you "covered"
I figured you wouldn't be able to wait too long to put these in !
I thought Arizen rears came with them??? I would think you could make regular pliers work...
