Sponsored by: DashLynx
i dont think im meant to be doing appearance mods right now
Old 01-07-2007, 10:46 PM
Z28_DAD's Avatar
Default i dont think im meant to be doing appearance mods right now
im having trouble polishing(posted in another thread) and now i have a painting problem
ok, painted my WP with VHT caliper paint. i see no problem with it, it has a higher temp rating then engine enamal, so WTF why not? so i painted it.
that was last weekend. this weekend, i go to the store and pick up some engine enamal and some clear coat. sand the VHT down a little bit and spray the engine enamal on. WTF!?!?!?!?! its like i just ******* sprayed it with ****** carb clean!!! and no i dont even have any in the garage, so it wasnt possible. how the **** did this happen??? anyone? im just going to strip it down and either polish it or paint it if im too ****** retarded to polish
Old 01-07-2007, 11:51 PM
Magnet's Avatar
sorry to see that man, i don't know why it would do that unless the two paints didn't like each other for some reason
Old 01-08-2007, 01:59 AM
6LITEREATER's Avatar
It's the clear coat... I've had that happen before. They aren't compatible because the clear is grabbing the paint harder than the paint can grab the surface therefore it is wrinkling it up...
Spray it without the clear or use a different base and clear... I say just spray it without the clear...
Old 01-08-2007, 02:47 AM
jebcamaro's Avatar
Every time I have seen paint wrinkle was because a) the paint underneath wasn`t allowed to have enough drying time, called solvent pop, b) the paint was applied to heavily or c) the paint underneath wasn`t prepped enough. If you painted clear over fully cured paint, cured by several days drying time, then you probably missed your window to top coat that particular paint. You should have put the clear over the base as soon as it setup enough to be topcoated, but still almost a bit tacky to the touch.
Old 01-08-2007, 06:45 AM
_JB_'s Avatar
It's possible you have an acrylic and enamel paints. You can use one on top of the other, but not vice versa.
Old 01-08-2007, 07:17 AM
Z28_DAD's Avatar
cant be the clearcoat, i havent sprayed it yet. the paint underneath had a week to dry, dont think thats the problem. the paint was doing this within seconds of spraying it on, in light coats BTW
i think JB hit it on the head, i think the caliper paint is acrylic. i think i tossed the cans out, but i painted my front cover the same way and it turned out perfect.
Old 01-08-2007, 11:28 AM
Xsta Z 28's Avatar
Dry time . . . seriously. If you do it too late, that's what does it.
Been there and done that . . . .
VHT, clearly states on the can, "For best results apply coats in 20 minute intervals. . . . "
Old 01-08-2007, 07:05 PM
smg267's Avatar
hit it with the wire brush and polish her up. I hit mine with a wire brush when I put on the new throttle body. It looks a million times better. Silver looks better IMO.
Old 01-08-2007, 07:08 PM
Z28_DAD's Avatar
id love to, but i painted under the pulley and will be a bitch to get under there. i have time, so i might
Old 01-25-2007, 09:49 PM
mycamaroSS's Avatar
dude that fuckn SUCKS, sorry
Old 01-25-2007, 09:55 PM
Z28_DAD's Avatar
it looks better now, i dont know what was wrong with it. i repainted it after sanding it and it looks alot better
Old 01-25-2007, 11:07 PM
Xx01CamaroZ28xX's Avatar
Damn that sucks bro, sorry to hear that happened to ya.....
Quick Reply: i dont think im meant to be doing appearance mods right now
