Sponsored by: DashLynx
clear corner lenses
Old 01-14-2007, 07:14 PM
nssane's Avatar
Default clear corner lenses
anyone else had problems with clear corner lenses?? i bought mine frome rksport, they were on my '02, then i took then out and put them on my '99. from the day i put them on the '99, my pass. side front blinker will only last 2-3 days, then pop. both of the lenses have moisture in them, but the driver side never pops.
Old 01-14-2007, 07:16 PM
slp#3130's Avatar
My driver side held water a 1 time.
Old 01-14-2007, 08:33 PM
Black Z/28's Avatar
I've had my clears for over 4 years and have not lost a bulb. I sealed them real well and I don't think I've ever seen any moisture in them.
Old 01-15-2007, 10:17 AM
Roarin_8's Avatar
Make sure you use bulb grease or you'll constantly blow bulbs. I learned that the hard way.
Old 01-15-2007, 10:32 AM
The Professor's Avatar
you need to seal them. i've had mine for 3 years, no moisture.
Old 01-15-2007, 02:13 PM
killerinparadise's Avatar
had them on my previous 2000 camaro for 2 yrs and had no bulb problems didn't even seal them
Old 01-15-2007, 06:21 PM
Jason26's Avatar
ive had mine on and never had a problem with bulbs or leakage
Old 01-15-2007, 07:31 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Mine would do the same thing. I had to drill a moisture hole in order for it to stop. Real easy to do, and worked great.
Old 01-15-2007, 09:14 PM
Yahelou's Avatar
so where do u drill the hole and how big?
Old 01-15-2007, 11:25 PM
Da Swami's Avatar
I drilled two tiny 1/16" holes in the bottom of the main housing.
Old 01-16-2007, 10:02 AM
WhosNXT's Avatar
I had the same problem, used bulb grease and ran a nice silicone bead around them and drilled small holes at the bottom. Problem solved!
Old 01-16-2007, 10:06 AM
95TAGary's Avatar
I've had no problen either for about two years. Do what WhosNXT did and you shouldn't either.
