Removal of interior panels (rear)?????
LS1Tech Administrator
Received 1,468 Likes
What's the trick to removing those hooks that hold in the plastic interior panels that cover the rear sail panel/B-pillar area? Do those hooks even come out? Or do you just loosen them and wiggle the panel out somehow? It seems like the center peice of the hook pulls out, but still I can't get the panel off.
I don't want to break anything during removal, but I can't seem to get the hooks out gently. What am I missing here?
Thanks.
Thanks.
Originally Posted by WILWAXU
The center piece presses in to lock it in place. Need to work it out first.
Thanks.
Originally Posted by 3.4camaro
you need to push the outer piece against the panel and try and work the middle piece out with a flathead. then pliars. then channel locks. those things blow
Thanks.
you are correct, it totally comes off of the outer piece.
if you feel like you broke something, you're only half-way there.
EDIT- i feel wierd giving advice to a guy with 9xxx posts. shouldnt i be groveling or something?
Thanks again.
