Rear seatbelt Torx bolt size
It's pretty up there. I didn't have one handy, so I managed to find a regular hex that would fit. It wasn't hella tight or anything, so it came right out without damaging it or anything. That was a nifty little trick I learned from an old boss, hex's work in torx... who would have known.
A 1/4" hex wrench will get the bottom bolt out.
Wound up leaving mine in...the whole seatbelt assembly is maybe 3lbs each side, so it's a negligible amount. I thought I read somewhere the entire assembly per side was like 18-20lbs, but it's nothing near that.
