how do i do the side molding mod?
hey guys, i tried searching for instructions on how to do the side molding mod, whats the proper way to do it on my '01 SS? will the paint under the molding make the rest of the car look faded? my car is black. thanks
The paint under the molding will probably look a bit fresher then the surrounding paint, esp being black. But after a good detailing, and some sun it shouldnt be as noticeable (I'd do a small section as a test to see. And dont just look at it close up, walk away and see it from multiple angles. Sunlight does some weird things.)
As for the procedure, its been covered many a time. Not tryin to be a search ****, but look around some of those threads about it. Then if you have anything specific - ask away.
i took some floss and used it to "saw" the molding off, then pulled the molding off. After that i just clay barred (SP?) to get the rest off, looks great now...
just do it on a warmer day and you wont need to use a heat gun
I didn't use the floss/fishing line, I just grabbed an edge and pulled the molding off. I used some GooGone (citrus base) and the rest of the adhesive came right off. It took about 20 minutes from start to finish.
