Sponsored by: DashLynx
Best Swirl and Haze Remover?
Old 02-22-2007, 09:54 PM
joejoe22's Avatar
Default Best Swirl and Haze Remover?
I currently just did a full detail with an adam's polishes essentials kit. They have a lot of great products but i found the swirl and haze remover to be kind of weak. It got out the medium swirls. Anyone try menzerna or meguiars? What is an aggressive swirl and scratch remover but safe for the clear coat. I have a black ws6 and it obviously shows every hairline scratch
Old 02-22-2007, 11:12 PM
osvaldo's Avatar
Megs #9. Or # 80. Or # 83 should help you out. #9 is the least abrasive #83 is the most abrasive. R you using a PC?
Old 02-23-2007, 09:51 AM
ZaneO's Avatar
Menzerna is by far my favorite line of polishes, but they require machine application.
Old 02-23-2007, 11:27 AM
BAD2000TA's Avatar
Another vote on Menzerna. Trust me - it works!!! But, you should use with the Porter Cable polisher. Well, at least that's what I did.
Old 02-23-2007, 07:18 PM
Pheonix's Avatar
Man i am a custom painter and i can wet sand with 1200 grit sand paper and take out swirls with one step with 3m 5936 or 6060 buffing compound, but you have to use a buffer with a foam pad.
Old 02-23-2007, 09:56 PM
Gipraw's Avatar
Meg's #80 then #9 or Menzerna IP then FP would be my recommendation, sight unseen, based on your comment that the adam's didn't cut it ..
Old 02-23-2007, 10:30 PM
DrkPhx's Avatar
Menzerna for me as well.
Old 02-23-2007, 10:33 PM
phrozen755's Avatar
to get my wirls out I used a claybar and the last 2 steps of the mcguier's 3 step (cleaner, polish, wax...only used the polish and wax) worked like a friggin charm!
Old 02-23-2007, 10:40 PM
PedroDePackas's Avatar
I would have to agree with everyone so far and also vote for Menzerna. I used it a couple of months ago and it worked great. It does dust some though, but its not a deal breaker.
Old 02-23-2007, 10:53 PM
wannafbody's Avatar
Menzerna is good stuff as is 3m
Old 02-24-2007, 02:30 AM
myfast70's Avatar
Menzerna here for me too. Here's what it looks like without the wax and just a quick glaze app for the photo shoot
Old 02-24-2007, 09:27 AM
TAEnvy's Avatar
DO the pads you use it on really matter. I have a little 6inch random partern buffer. All I can find is these cloth bonnets and I dont know when to use each one
Old 02-24-2007, 09:36 AM
CashMoney's Avatar
I've never used mernerza but I accomplished this with Megs #9 and orbital buffer. Edit the pads and cloths you use make a huge impact on the quality of your work.
Old 02-24-2007, 10:36 AM
myfast70's Avatar
Here is the pad kit that I use for my polisher. I use the porter cable 7424 polisher. Here is a good starter set if you don't have anything right now. You can buy a full Menzerna kit that should cover everything you need but a clay bar. A lot of people on here use Zaino. I've never even heard about it until I came to this forum. It seems to be a great product too. Hopefully this will help a bit.
Old 02-24-2007, 11:16 AM
joejoe22's Avatar
I do have a PC. I have the double sided, orange and green pad. Also i have the white polishing pad and another double sided pad(black and white). I bought the essentials kit of the adam polishes website. Which product from menzerna do you reccommend that will just get my swirls out. I'm happy with the adams products except for the swirl remover. It's just too weak.
Old 02-24-2007, 11:27 AM
noxiouSS's Avatar
damn.
Old 02-24-2007, 01:37 PM
ZaneO's Avatar
Menzerna Intensive Polish followed by Menzerna Final Polish.
GM clearcoat is quite hard and may require several attempts to correct.
Old 02-24-2007, 06:39 PM
joejoe22's Avatar
ZaneO, do you reccoment menzerna for sure? Have you tried both or do you just know that menzerna is better? If there isn't a big difference i would get mcguiars because i know autozone carries it, and i'm anxious to try it tomorrow. Is menzerna carried in stores or just online?
Old 02-24-2007, 06:43 PM
ZaneO's Avatar
I've been using Menzerna for about 4 years. It produces the best results out of many, many polishes I've tried.
Other polishes like Meguiar's will still produce good results, but Menzerna is what *I* consider to be the best. YMMV
Old 02-24-2007, 06:46 PM
joejoe22's Avatar
Can i pick up menzerna at like an autozone or murrays?
Quick Reply: Best Swirl and Haze Remover?
