Sponsored by: DashLynx
Removing tint on back window with defroster lines?
Old 03-01-2007, 11:36 AM
trevorborden's Avatar
Default Removing tint on back window with defroster lines?
whoever had my firebird before me had a bad tint job done, and its bubbiling and unclear, also it looks like alot of the tint was ripped off leaving just a thin sticky layer left. Normaly I remove my tint with some go gone and a razor blade, but how do I remove tint on the rear window with those heater lines? I don't want the goo gone to mess those up, or my razor blade to scratch them off.
Old 03-01-2007, 12:15 PM
95greenZ's Avatar
use some rubbing alcohol, won't hurt electronics and brings the sticky stuff off easily. Thats what I used to get tint off my doors. Just be sure to clean it after your done.
Old 03-01-2007, 12:22 PM
95greenZ's Avatar
I just reread your post, I see you still have some tint on it too. Just use your razor blade to get it started and then use a hairdryer to heat the film and it will come off easily and then use the alcohol to get the little bit of glue that remains.
Old 03-01-2007, 02:43 PM
Kage's Avatar
Thumbs up
Ammonia/water 50/50
Old 03-01-2007, 08:28 PM
FNQUIKWS6's Avatar
purple power cleaner!!! the best stuff all you have to do is spray it and let it sit for a few minutes and wipes right off. i only went over my back glass twice and it was all gone
Old 03-01-2007, 09:08 PM
Duffster's Avatar
do the ammonia thing (50/50) OR use alot of Windex.....
Old 03-01-2007, 10:04 PM
Rhedalert's Avatar
I used a handheld steamer with good results!
Old 03-01-2007, 10:16 PM
Zymosis's Avatar
"My" tint guy used a clothes steamer to remove tint from the back window. Worked like a charm.
Quick Reply: Removing tint on back window with defroster lines?
