Sponsored by: DashLynx
funny blinker
Old 03-03-2007, 02:55 PM
01CaMMMaro's Avatar
Default funny blinker
my blinker seems to stutter alot lately... itll blink normal for a few blink's then will pause for sometimes as much as 5 seconds between blinks. its doing this on both sides. i know my blinker lights around going out because if they were then it wouldnt blink at all. could it be the gauge lights?
Old 03-03-2007, 09:43 PM
01CaMMMaro's Avatar
ttt... im getting annoyed by this damn blinker!!!!!
Old 03-03-2007, 10:50 PM
ICEMAN 31's Avatar
have you looked at it from outside the car
Old 03-03-2007, 11:13 PM
01CaMMMaro's Avatar
ya i have and the lights are lighting up fine... just getting a bad stutter
Old 03-03-2007, 11:17 PM
1QuikZ's Avatar
try replacing the blinker relay under the dash. hope that helps.
Old 03-03-2007, 11:21 PM
Revelation Z28's Avatar
low on blinker fluid? check the blinker resivoir
check the wiring too if you can, or like said the relay.
Old 03-03-2007, 11:25 PM
01CaMMMaro's Avatar
could it be a fuse? also where is the blinker resoivoir and the blinker relay? im not good with electronics usually.
Old 03-04-2007, 01:21 AM
NightWindDriftr's Avatar
Me neither, and even I know that there's no such thing as a "blinker reservoir".
Old 03-04-2007, 02:38 AM
deimis's Avatar
This same garbage is happening to me. I've check all the wiring for shorts, none that I can find. All the lights are brand new and I even put a new flasher in...still having this issue. I'm gonna check for a fuse/relay next.
Old 03-04-2007, 01:26 PM
sobaka79's Avatar
check your trouble codes,
anyway, i replacd my alternator and it fixed my electrical problems, which included slow blinkers, it sounds like something in your accesory drive is messed up..
Old 03-04-2007, 01:33 PM
lol blinker fluid and the resivoir doesnt exist.
the relays are on the drivers side of your dash. open up your door and you should see a slot to stick your finger in. but dont worry nothing will bite you. pull on that piece and it should un velcro itself so you have access to your fuses.
Old 03-17-2007, 05:16 PM
01CaMMMaro's Avatar
i replaced fuses and the relay... still have the same problem. I HATE ELECTRIC ****!!!!!!
Old 03-17-2007, 10:26 PM
Raleigh TA's Avatar
Replacing bulbs solved it for me a couple of years ago...Electrical problems can be a PITA! Good Luck
Old 03-17-2007, 11:47 PM
blackrat's Avatar
Check ALL the bulbs. If it's a left turn signal, there's two in the front and one in the back. Also check your brake lights and make sure both filiments are lighting up, low and bright.
I had hte same thing but it was the relay under the dash. Replaced it with a heavy duty one and problem solved.
Old 03-20-2007, 09:49 PM
MMotorsports's Avatar
could be your multi function switch?
Old 03-21-2007, 12:00 AM
1meantransam's Avatar
Old 03-21-2007, 11:08 AM
schtick's Avatar
Originally Posted by deimis
...and I even put a new flasher in...still having this issue. I'm gonna check for a fuse/relay next.
This happened on my vette. It was the hazard switch. I replaced it and all is well. That doesn't help you much since you replaced yours already, deimis. I'd do like you said and check out the fuses/relays. This may help 01CaMMMaro, though. Maybe try out the hazard switch. Don't know how much difference there is between a vette and an F-Body but it's worth a shot.
Old 03-21-2007, 11:17 AM
Breaking Stuff's Avatar
There is fuse that looks like a canister under your dash. You have to take off the panel above your knees. It will be about right above where your right knee points. It will be clipped inside of a rail that makes it hard to see it. Look for wires going behind a rail and a clip on the out side of it. It took me 15 minutes to find it but its there. Good luck.
Quick Reply: funny blinker
