Sponsored by: DashLynx
fire extinguishers
Old 03-05-2007, 12:04 AM
never2low's Avatar
Default fire extinguishers
Anyone have pics or ideas where to put them in a t/a ?
Old 03-05-2007, 05:41 AM
Pretyflywiteguy's Avatar
Old 03-05-2007, 07:08 AM
98WsSick's Avatar
its not rice when your cars on fire and you have a 10lb nitrous tank in the back. Ive seen them on the passengers side pillar
Old 03-05-2007, 07:25 AM
Rehab is for quitters...
XtinctZ28's Avatar
Originally Posted by Pretyflywiteguy
Now it is rice to protect your car from fire? I wish you newbie "rice dispensers" would shut the **** up.
Here is some more info from another thread: https://ls1tech.com/forums/showthrea...+extinguishers
Old 03-05-2007, 07:28 AM
Rich189's Avatar
ive seen a small one mounted on the hump between the back seats... also behind the drivers seat on the floor (because no one fits there anyway)
Old 03-05-2007, 09:06 AM
LS69TA's Avatar
Keep it out of sight but close enough to reach. Everytime I see one mounted on the A-pillar I just want to slap somebody. The driveshaft hump between the rear seats would be a decent place and easy to reach if needed.
Old 03-05-2007, 09:46 AM
never2low's Avatar
Thanks for the help guys although I didnt know having one to save your investment would be considered rice.
Old 03-05-2007, 10:17 AM
bjamick's Avatar
Ok having a fire extinguisher is not rice at all, its caring for your car. I've been wanting to put one in my car for awhile since i put the nitrous on just in case of a nitrous explosion and something was to catch on fire. I would hate to see my car just burning and theres not **** i can do about it.
Old 03-05-2007, 10:40 AM
LS1B|RD's Avatar
NAWWWZZZZ!!!!!!!!!!!!!!!!!!!!!!!
*boom*
LS1B|RD's Avatar
oh... to answer your question, i say put it on the A-pillar
Old 03-05-2007, 11:08 AM
brandonppr's Avatar
Why does it matter of you have nitrous or not?
Old 03-05-2007, 11:26 AM
dfreeman2386's Avatar
nitrous + fire = BIG BOOM!!!, therefore you have to try to put the fire out before it gets to the nitrous, not rocket-science.
Old 03-05-2007, 11:42 AM
Luna's Avatar
I would really like to put an extinguisher in my car I would hate to watch it burn to the ground and be totally helpless. Are those small ones (like you see mounted on the A pillars) even very useful ?
I would like to see where people have them mounted.
Old 03-05-2007, 11:50 AM
LS1B|RD's Avatar
i thought nitrous was not flamable?
Old 03-05-2007, 12:01 PM
LS69TA's Avatar
Nitrous isn't flamable. It's just nitrogen and oxygen. It promotes combustion. He must be talking about a nitrous backfire.
Old 03-05-2007, 12:04 PM
LS1B|RD's Avatar
too much fast and furious maybe???
Old 03-05-2007, 12:26 PM
~JOSHUA's Avatar
I have a large extinguisher on the floor behind my seat. It's not mounted, it's just lying on the ground propped up so it can't roll around.
Old 03-05-2007, 12:28 PM
brandonppr's Avatar
http://www.linweld.com/msds/NitrousOxide.PDF
It should not expode unless it his heated to a high temp and that should take a while, by that time the pressure cap should blow off and by that time if you have not got it out your car is probley toast anyway. the nos should also be vented to the outside of the car so that if the cylinder blows the pressure cap it will go outside. if not it is kind of like taking an air compresser and spraying air on the fire. it would put it out unless there is fuel and in that case the air blowing on the fire would help the fire.
however I do believe a fire extingquisher is a good idea but the Fast and the Furious makes it look like the car would just explode because of the "nauzz", its just Hollywood making it more exiting to the viewer
"Fire and Explosion Hazard DataFlammability Classification:NonflammableFlash
Point (F):N/ALEL (%):N/AIgnition Temperature:N/AMethod:N/AUEL (%):N/A
Extinguishing Media:Copious amounts of water for fires with nitrous oxide as the oxidizer.
Fire Fighting Procedures:If possible, stop the flow of nitrous oxide, which is supporting the fire. If cylinders are involved in a fire, safely relocate or keepcool with water spray.
Fire & Explosion Hazard:Nitrous oxide may decompose violently at temperatures above 1112oF.5. Reactivity Data
Stability:StableHazardous
Polymerization:Will not occurIn
compatibility:All flammable materials.
Conditions to Avoid:N/A"
navymitch12's Avatar
nitrous is not flamable but it will make any fire that is burning burn faster and bigger.
i would just stick it on the floor infront of the pass seat.
and for the guy who said rice....i noticed your sig says 2 small oil leaks. when those catch fire and you dont have anything to put it out cause its "rice" have fun with a melted trans am
Old 03-05-2007, 12:37 PM
John inNH's Avatar
Just a little FYI.
Nitrous Oxide is not flammable, it's an oxidizer. What that means is it supplies more oxygen to an existing fire, in a nutshell it makes a small fire REALLY BIG!
A nitrous tank, like any compressed gas tank can explode if heated sufficiently, such as sitting over a burning gasoline tank This is called a BLEVE (Boiling Liquid Expanding Vapor Explosion). This will pretty much look like a car bomb explosion. A fire in a car with nitrous is not a fun thing to respond to. As far as an extinguisher, I keep mine on the floor behind the drivers seat.
John
(Captain, local Fire Department)
