Sponsored by: DashLynx
yet another halo install question...
Old 03-17-2007, 03:34 PM
reocamaro's Avatar
Default yet another halo install question...
I installed my halos and wired them to my fog light. My fog light works but i'm not getting anything for the halo. :-\ Any suggestions?
Black to black and purple to red. :-\
Old 03-17-2007, 05:39 PM
98BirdLS1's Avatar
Mine did the same thing. Turned out to just be a bad LED in the headlight. I had to send the whole headlight back and they sent me another one within a week. Try wiring in the opposite sides light to see if it works.
Luke
Old 03-17-2007, 06:05 PM
Havok2's Avatar
maybe you wires them wrong.
to check he led. put the red to power. white to a ground on the battery, thats how i checkd to see if they worked before i installed them
Old 03-17-2007, 07:15 PM
reocamaro's Avatar
that sounds like a genius plan.
Old 03-17-2007, 08:14 PM
SSU's Drunk Typing Whore
Lithium's Avatar
hey man I found a good write up for you ------> https://ls1tech.com/forums/showthrea...highlight=Halo
It sounds like there is something wrong with the headlight though cause it should of lit up. If not double check all the connections etc...
Old 03-17-2007, 09:19 PM
SSNISTR's Avatar
Make sure your ground is GOOD, they are finiky and like good grounds.
Old 03-18-2007, 04:14 PM
reocamaro's Avatar
Turns out the ground must not have been as grounded as the wire wanted it to be, hooked it up to a screw as shown in a pic above and it works perfectly. Thanks everyone.
