Sponsored by: DashLynx
led turns
Old 04-07-2007, 01:26 AM
slvrta2002's Avatar
Default led turns
i just did the Hid conversion for my car and i'm looking to put led's in the turnsignals, where is the best place to get them from i belive the bulb number is 3157, and i heard i need some kind of load resister? to make the bulb flash. it a 2002 ta. thanks in advance.
Old 04-07-2007, 01:14 PM
Silver UltraZ's Avatar
ebay...
Old 04-07-2007, 02:35 PM
Trojan35's Avatar
if you're goin for a really cool look, try this:
http://www.paveglio.com/firebird/2001tamods.html
Old 04-07-2007, 03:40 PM
Transamin00's Avatar
look up the 3157 switch back.
its white when the running lights are on, and amber when the DRLs and turns are on.
you might want to think about doing the DRL mod.
you will also need an electronic turn signal flasher.
Old 04-08-2007, 09:28 PM
slvrta2002's Avatar
does anyone know the part number of the electronic turn signal flasher?
Old 04-08-2007, 10:53 PM
slvrta2002's Avatar
Ttt..
Old 04-09-2007, 05:39 PM
slvrta2002's Avatar
bump.............
Old 04-09-2007, 07:38 PM
just search for a 3 prong electronic turn signal flasher. if you cant find one, pm me and i will give you some links.
Old 04-09-2007, 07:55 PM
Blackbirdws6's Avatar
EL12 flasher, need one for hazards and turn signals. I love my switchbacks
Old 04-11-2007, 10:13 PM
slvrta2002's Avatar
is EL12 only for lt1's? or both ls1's and lt1's, transamin00 said a 3 prong and i just seen the picture of the EL12 looks like its only a 2 prong.
Old 04-12-2007, 02:26 PM
slvrta2002's Avatar
bump!
Old 04-12-2007, 03:24 PM
SCRWS6
Guest
Posts: n/a
if your ls1 you only need one flasher, I originally bought 2, but you only need 1, just switched out the other car too
Old 04-12-2007, 03:25 PM
SCRWS6
Guest
Posts: n/a
and it is only two prong....
Old 04-13-2007, 07:10 PM
slvrta2002's Avatar
ok awesome, thank you very much, i've been waiting to order till i found out for sure
Old 04-13-2007, 07:57 PM
1meantransam's Avatar
is that your car man? looks sick if thats yours message me and tell me all the details to get my front like that
Old 04-14-2007, 12:10 AM
00WS6_TA's Avatar
That looks sweet as hell... What all did you do? I bought the corner lights like yours but the kept blowing on me every day.
Old 04-16-2007, 08:28 PM
ZROCWS6's Avatar
Where is the flasher located? Its only a TWO prong? That sucks because I bought 2 THREE prong flashers. I havn't oppened them yet thankfully.
Old 04-16-2007, 09:28 PM
ZROCWS6's Avatar
Ok. I found the flasherS. The turn signal one is to the right and the hazard one is to the left after you remove the lower dash cover under the steering column. I DID have the two prong flashers not the three prongs like I thought. I got them installed and the switchbacks look friggen sweet!
Old 04-17-2007, 07:44 AM
only down side to the switch backs are when the running lights are on, the amber is a bit washed out by the white. but i added a 2nd amber led to combat that problem.
headlights are HIDs
turns 3157 switchback + 3156 amber tower LED
fog 3157 white tower LED
Old 04-17-2007, 06:56 PM
ZROCWS6's Avatar
How did you add a second amber LED?
Quick Reply: led turns
