How can I re-finish Billet rims?
Old 04-17-2007, 07:35 PM
Humanitarian
Joe "Preachers Sheets" DIESO's Avatar
Default How can I re-finish Billet rims?
am going to try to re-finish a set of Billet (raw alum) rims myself. Time isn't an issue, I have lots of it.
The rims are not that bad, the inside obviously is a little worse than the face. The lip's have a little bit of pitting that you can see from one foot away.
Can I use this procedure:
Spray some sort of stripper on them that would be used to remove clearcoat, just for a cleaning.
Sand the rims down with a multi stage process of tougher grit to smoother?
The other idea is to pay someone to sand blast them and clear coat them. What do you guys think?
Old 04-17-2007, 07:44 PM
AbsolutHank's Avatar
Those first two steps are the exact process I had to use on my old TT2s...you gotta have a set of ***** though - I could barely throw acid on them the first time...lol
Old 04-17-2007, 07:51 PM
Humanitarian
Thanks!
How did the wet sanding go? I would think it would leave micro scratches right?
My plan for that is use 0000 grade steel wool then a polish. If you had micro-scratches after the wet sanding, how did you attack them?
Quick Reply: How can I re-finish Billet rims?
