Plastic Headlight housings?
Nope I'm talking about the sealed beam low beam headlight housing that came on most of the cars from the factory. Most aftermarket headlights are glass. But few were plastic.
Originally Posted by LILWS6
where you find those at thats what i'm looking for?
No I don't want glass housings, I need plastics ones so I can basically do the same thing. But looks like I'm gonna have to go completely custom because once again GM uses dated technology
Copy & Paste Moderator
What are you trying to do?
I recently installed Hella H9 Projectors in my 2001 Formula. I read through some threads over on Full Throttle V6 and gave it a shot.
http://www.fullthrottlev6.com/forums...ad.php?t=22874
http://www.fullthrottlev6.com/forums...ad.php?t=23020
http://www.fullthrottlev6.com/forums...ad.php?t=23217
http://www.fullthrottlev6.com/forums...ad.php?t=23289
http://www.fullthrottlev6.com/forums...ad.php?t=23782
I found those threads searching Google at 1AM about a week ago (I was still searching for info at 2AM... Donaimian can tell you how much sense I wasn't making at that time in the morning).
Guest
Posts: n/a
you can get the housings with bulbs at autozone, just stocker replacements that you can remove the bulbs and use what you want, otherwise some good links above..... I only used these for high beams though, bought some projectors off ebay for the low beam
I've never seen them.
Thats news to me.
Any pics, prices?
Unless you are talking about making a conversion housing using stock replacements. I did that for a while, but I didn't like it.
Guest
Posts: n/a
exactly... its hella easier than trying to remove the bulbs from the all glass ones....spent quite a bit experimenting with em, you know how projectors are deeper than our lights? turn em around inside the bracket that holds the headlight on. gives you more room inside and the headlight still opens and closes just fine....I go crazy tryng to get some of this stuff to work ....
