Sponsored by: DashLynx
LED 194 Bulbs Not Working!?
Old 05-03-2007, 02:30 PM
Brutal LS1's Avatar
Default LED 194 Bulbs Not Working!?
I just installed my white face gauges and also bought 8 LED 194 bulbs from pep boys for like 8 bucks a pair...I took all the old bulbs out and popped the new ones in their place and twisted them back into the cluster. All the needles work fine but the bulbs don't illuminate at all. Did I miss something here? There's no way that all 8 bulbs are bad. Is there something special that needs to be done to the prongs of the LED bulbs??
Help!
Old 05-03-2007, 02:36 PM
Havok2's Avatar
you might have to remove and flip them.
some are polariezed, there is a wrong way/right way of instlling.
Old 05-03-2007, 02:47 PM
SuperSport's Avatar
Yep, turn them 180 degrees and try again.
Old 05-03-2007, 03:01 PM
SStealth00's Avatar
why did u buy 8 you only need 5 for the gauges
Old 05-03-2007, 08:46 PM
Brutal LS1's Avatar
turns out they were actually all installed correctly...just really dim. Ihad to put the cover over the car just to realize they were working. Swapped 'em out and put the old stock bulbs back in. Note to anyone buying single 194 LED bulbs from pep boys - they suck and aren't bright.
Quick Reply: LED 194 Bulbs Not Working!?
