Blacking out tail light filler pannel?
Old 05-16-2007, 06:15 AM
GTObsessor's Avatar
Default Blacking out tail light filler pannel?
I've seen it done before but can't find a write-up on the best/easiest way to do it. I've heard of wetsanding then using plastic polish to smooth it back out. Is this the best way? I don't wanna end up with a bunch of swirls at the end and I don't have access to a PC. Details please
Thanks
Old 05-16-2007, 07:07 AM
Smoke Panther's Avatar
https://ls1tech.com/forums/appearance-detailing/443159-appearance-hall-fame-threads-check-first.html
read the stickies
Old 05-16-2007, 05:02 PM
DirtyBird222's Avatar
I wetsanded mine, with 400 and 600 grit. Sprayed some sandable primer on it, sanded it until it was completely smooth. Painted with black GM code paint, clear coat and Bam I was done. I've done it four or five times now. I have an extra one laying around.
Old 05-16-2007, 07:52 PM
GTObsessor's Avatar
Originally Posted by Smoke Panther
Woopse. Didn't see it last time I was browsing the stickies. Sorry about that and thanks
Old 05-17-2007, 12:01 PM
Z28LS1camaroguy's Avatar
Just wetsand it, even if you get some swirl marks after sanding the primer should cover them up and then when you paint it you wont even see them.
Quick Reply: Blacking out tail light filler pannel?
