HELP! 2 bolts stripped on my VFN
This is a 4" VFN ram air and just like the title says I have 2 bolts where the hood bolts to the hinges stripped and won't back out(not tight eighter). Even tried prying against the washer as i tried to back the bolts out. For some reason my factory bolts are only going in half way and the strip. I had to put 2 washers extra on the rest of the bolts and they tightened up good. Has this happened to anyone else? Does anyone know how I can get them back out?
Thaught about that but it's too dark now, maybe I can pull on them while backing them out. The bolts are just spinning they won't tighten down any further and they won't back out eighter.
this SAME thing happened to me. my hood is a harwood though. i put the hood halfway on with the stock bolts and realized that i couldnt screw them all the way in or take them out. what i ended up doing is drilling a hole in the side and just getting a wrench in there and using a normal bolt and nut... its a pain in the *** and looks like ****, but maybe you'll have better luck. Anyway, that's what i did..
No I figured out to shim the bolts to make them shorter by the time I got to the that stuff. Guess I'll be cuttin some holes in her this week to get it bolted down good. I did drive it to work last night and you absolutely can't see over this thing, it's FN huge! Got 5-6 compliments on it in the first 10 min I was there.
