Sponsored by: DashLynx
Shortening the length of the stock A4 Automatic Shifter????
Old 05-22-2007, 09:34 AM
White_LightningZ's Avatar
Question Shortening the length of the stock A4 Automatic Shifter????
Wondering if anyone has done this in their camaro. I think it would look cleaner with the **** closer to the gate. thanks and post pics if you have any
Old 05-22-2007, 09:40 AM
TXZ28LS1's Avatar
ive been thinking the same thing!!!
Old 05-22-2007, 09:47 AM
tylerdj's Avatar
There was a thread on this a while back...I'll search and see if I can find it.
Old 05-22-2007, 10:01 AM
kaos_'s Avatar
i shortened my trans am auto **** and it looks wayyyy better. it sticks out so high stock, looks like you could churn butter with it! i'll get pics in a sec.
Old 05-22-2007, 10:11 AM
sbusby's Avatar
Are there any aftermarket ***** you can put on that make it look, not so.. bleh? My leather is starting to fade on it... the only thing in the car that is fading.. bleh
Old 05-22-2007, 10:32 AM
Copy & Paste Moderator
VIP1's Avatar
Shorter shifter & aftermarket ****:
https://ls1tech.com/forums/showthrea...3&page=1&pp=20
Other aftermarket *****:
https://ls1tech.com/forums/appearance-detailing/476760-automatic-shift-knob-conversion-kits.html
https://ls1tech.com/forums/appearance-detailing/510891-auto-shift-knob-options.html
https://ls1tech.com/forums/appearance-detailing/507571-auto-knob.html
https://ls1tech.com/forums/appearance-detailing/474757-retro-shift-knob-auto.html
https://ls1tech.com/forums/showthrea...&page=11&pp=20
https://ls1tech.com/forums/showthrea...&page=17&pp=20
Here is how I added a shift boot to my A4:
http://www.fadingarrow.com/ShiftBoot.htm
Readline Goods also sells leather shift and e-brake boots.
Old 05-22-2007, 12:33 PM
kaos_'s Avatar
I think the MKIV Supra auto **** is perfect for our cars. I got a hold of one and am going to have to custom fit it somehow. I just like how they look.
Old 05-22-2007, 03:36 PM
Brian2006's Avatar
Shortened mine also. Let me know if you need help doing it:
Before:
During:
After:
Old 05-22-2007, 04:04 PM
Ls1CamaroGuy87's Avatar
Did you reinstall that little clip shaped like a U? And how did you cut the metal without hitting the white plastic on the inside of it?
Old 05-22-2007, 04:06 PM
kaos_'s Avatar
Dremel and a steady hand!
Old 05-22-2007, 05:19 PM
TXZ28LS1's Avatar
man thats pretty cool!!
Old 05-22-2007, 07:26 PM
Brian2006's Avatar
Very carefully and strategically
I used a small cutting wheel and dremel and cut it exactly how it looked like before. Except an inch shorter.
Old 05-22-2007, 07:28 PM
^yeah thats what I was going to do....I hope my hand stays steady
Old 05-24-2007, 06:46 PM
Before:
During:
After:
looking good! I was thinking of making the bottom of the **** flush with the gate or a 1/4" above it. not sure if that is too low or not? thanks for the pics and everyone else who posted info!
Old 05-24-2007, 07:13 PM
Brian2006's Avatar
That would be too low. The plastic shaft inside the metal piece is only so short and if you cut it that low there wouldn't be anything to cut. You'd be cutting a spring. Because you only have about an inch and a half to cut before you hit the end of the plastic shaft and cut a spring. You'll see what I'm talking about when you get there.
Old 05-29-2007, 04:48 PM
FadedSS's Avatar
very nice. im attempting this weekend!
Old 05-29-2007, 06:00 PM
Brian2006's Avatar
Should be very easy. PM if you need any help
Quick Reply: Shortening the length of the stock A4 Automatic Shifter????
