Meguiars Scratch X....uh...is this intended to create scratches?
Ok, so I had some very minor scratches on my driver side rear fender and I figuered I'll try this stuff out. I used a brand new Zaino applicator pad to to apply this stuff, and the car was more than clean when I started using it. I did it in the garage with the door closed during daytime hours, and after some rubbing (thorough rubbing), and removal with a tropiccare microfiber towel, the damn thing did nothing to those scratches. So I think to myself, ok, lets try the reaaaaaaaaallly fine ones on the passenger side, they shouldn't be a problem since you can only see them when in direct sunlight, and even then you have to look for them. So I follow the same procedure, and after I am done removing it....the scratches are now way worse!?
Are you supposed to use something else after you apply that stuff?
I really don't want to spend more money on the stuff they recommend on the Meguairs Scratch X tube. The whole car is newly Zainoed with 3 coats of Z5. I do have the Meguairs cleaner wax here as well as the polish stuff from their 3 step program, should I try to use one of those and then top it off with more Z5?
Thanks!
Manny
Thanks!
Manny
I have a few scratches on my car for which I've been using Scratch X. It really worked for me, but you need to work really hard on each scratch (with a clean applicator pad). I put as much pressure as I can and rub rub rub each scratch for maybe 20 minutes. At the end, the scratches have not disappeared but are a lot smaller and hard to notice. I'm sure they would disappear if I was to insist, but as is the scratches don't bother me anymore.
Is the idea though to have to go back over it with some sort of polishing wax to make it look good? Because so far it only made it look worse?
20 minutes? Holy Cow! I am guessing you periodically apply more of that stuff on there since it kinda rubs itself dry after a while. The second set of scratches were really fine...coudn't feel them with the fingernail and were almost hard to see, they showed up clearer after the first application of that stuff.
I'll try again tonight.
It worked on my car and it's great. It works on alot of NOT through clear coat scratches. Have you had any body shop experience? With wet sanding/buffing and such?
No wetsanding or real body shop expierience, just the basics of how to keep the car clean...use the right products, do the clay thing and using Zaino.
I just looked over the car again, and for some reason I can't find those scratches I saw yesterday anymore.
Don't know....maybe due to the lack of direct sunlight.
Originally Posted by ls1owner4life
careful or it might take off some of your clear coat
Theres no way ScratchX would go through clear... technically its possible but it would take more applications then a tube of ScratchX could supply.
I used something along the lines of scratch X with my porter cable on some deeper scratches (could barely catch them with a fingernail). Didn't do crap. Of course, neither did my Menzerna intensive polish with an orange pad so maybe they need a bit more attention than scratch x Just putting my .02 in.
Originally Posted by GTObsessor
All meguires products for scratches and swirls that I've used require some good ole elbow grease but they do work. Just that you gotta work too lol. Porter cable ???.
Originally Posted by Revelation Z28
what about the light scratches on the roofs? i have a shitload of them only when light hits it certain places.
Guys it's gonna be tough to remove any imperfections with your hands. But if you want to get em out your gonna have to really dig in and use some elbow grease and some time. Stuff like that was meant for buffers and porter cables.
Anyone tried Kit Scratch Out? That stuff is miraculous. When I got my car, it looked great. After a couple washings, I could see all the haze from the compound, the entire car looked awful. I used Scratch out on the entire finish, and it looked 95% better. Used Meguiars Hand Glaze #9 after that and it looked just about like a new car. I now use Scratch Out as a spot scratch remover, followed by #9, then wax. Important to use clean applicators and removers, especially with a black car. I use Kleenex, which leaves lint, but the lint is easy to remove. It allows me to use a fresh cloth every spot I work on without bankrupting me.
I used it on my Z right after I bought it because there was a hazy apearance when direct sunlight hit it, plus swirls all over.
It was definately a PITA to use, being you have to put a fair amount on because it doesn't coat large areas like other products you might use, and it sucks taking it off. Definately took some elbow grease, but when I was done I was VERY pleased with the results...
Before I scratch x in direct sun there was haze and swirls...now you can see there weren't after I finished it..
And just a shot of the door and hood to show how clear it looked after..
