gear shift indicator light removial
Put shifter in first gear. Remove the metal pin out of the front of your shift **** with a flathead or some sort of pliars. Remove shift ****. Open your center console, take out the change box, remove the two 7mm screws. Pop the console lid off starting from the back and then the front. Twist and pull out shift indicator light.
