my hood (56k warning)
well i finally washed the car after 3 weeks of letting the paint cure. still need a month until i can wax it i took these with the last remaining light outside. the body shop took care of the pinholes it had from the gelcoat. but i guess all aftermarket things have their flaws. my front bumper is next to be painted and re aligned. its not a VFN or glasstek by the way. i forgot the company's name.
If you want to get rid of imperfections, spread some body filler on real thin and sand it smooth. Use a sanding block and, if done well, it will eliminate the flaws in the surface.
