anyone have a nice low key shift light??
Old 06-26-2007, 07:06 PM
sprung_monkey's Avatar
Default anyone have a nice low key shift light??
well after my first run with this car i know im going to be needing a shift light........i got wayyy to used to a4's with just looking straight head while running and im not looking to over rev this motor
but i dont want some huge shift light hanging either..........does anyone have a nice clean install they can show me??
Old 06-26-2007, 07:13 PM
Fb0dy0nly's Avatar
get a harlan or raptor, I know raptors are on sale till the end of the month. They can go pretty much anywhere, including your driver defrost vent. I would post a pic but I do not have one yet, hopefully this week....
Old 06-26-2007, 07:29 PM
98redM6's Avatar
The Harlan and Raptor shift lights are both cool. They are both small and serve the purpose without creating clutter. The Harlan is about $60 shipped and the Raptor is about $85 shipped. Take your pick. My brother just installed his Harlan shift light after having it sit for 6 months and it took him about 20 minutes.
Old 06-26-2007, 07:30 PM
Ling_650vette's Avatar
One of the cleanest pics I could find (BIG MIKE2005s car)
Either there, or in one of the AC vents seems to be the most popular for more stealth installs.
Old 06-26-2007, 07:45 PM
SPECIALIZED STAINLESS's Avatar
I've got a Harlen w/ a custom aluminum bezel I made...
Old 06-26-2007, 08:09 PM
^thosetwo look great i think i wanna go that route........
toofazt-how much would you do another one of those for?
Old 06-26-2007, 08:14 PM
00PewterSS's Avatar
They are $55... http://www.harlan-engineering.com/store/store.html
I installed mine the same location as above. Except instead of an aluminum bezel I cut out the louvers in the defrost, cleaned it up and used that as my bezel. Lights works great.
Brian
Old 06-26-2007, 09:25 PM
DropTopBird's Avatar
Just a though. If youre looking at putting gauges in, you might want to look at the interceptor scan gauge. It has a built in shift light in it that works pretty well. I have an auto so I have no use for it, but I set it to 5000 anyway just to play with it. When it hits the mark at wot its a nice bright light right on the dot.
Old 06-26-2007, 09:32 PM
BlackBADaSS02's Avatar
I have a raptor installed in my center A/C vent. I never did get around to take any pics of it installed. It was very easy to install. At the most it should take 30 min.
Old 06-26-2007, 10:07 PM
ls2 bait's Avatar
raptor
Old 06-26-2007, 11:04 PM
Can't make another. Made it when I was working at a machine shop, sorry.
Old 06-27-2007, 01:00 AM
brandonppr's Avatar
I mounted mine in behind the AC vent. I used a LED light with a socect from aotozone and wired it to my RPM switch. You only see it when it lights up.
Old 06-27-2007, 09:25 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
MPH Motorsports is running a special on the Raptors right now.
Great customer service and very fast shipping
Old 06-27-2007, 10:31 AM
ICEMAN 31's Avatar
anyone every try putting a piece of tinted lexon over the light, so you loose that "flower of light look" and it looks cleaner, i seen it done only once never saw it again
Old 06-27-2007, 11:00 AM
tc3
tc3's Avatar
I didnt want my shift light noticable at all... soo i have two led's in both of the bolt indentions for the trim around the cluster... I never see the lights directly, but when they light up i can clearly see it...
Old 06-27-2007, 01:00 PM
clean99's Avatar
I just bought a harlan and mounted it behind the center ac vent in my camaro. you cant notice it untill the light comes on, day or night you can see it clearly, i like it
Old 06-27-2007, 02:39 PM
ls1owner4life's Avatar
Which one is brighter and fits better or are they the same size?
Old 06-27-2007, 03:10 PM
slow1999blackz28's Avatar
the blue raptor light is very bright and works great but my questions is why arent you getting a 4 inch tach with a huge shift light that would be great haha only kidding
Old 06-27-2007, 03:17 PM
you mean 5 inch! lol...
Old 06-28-2007, 09:22 AM
Dal1as's Avatar
Can't remember the brand but I installed mine in the dash bezel.
You can see it above the odometer in the below pic. Eventually I'm going to get a new Bezel and do a cleaner install. I cut the hole too big when doing this and it stuck out farther than I wanted. I may also try mounting it behind the instrument cluster.
http://www.carstereo.com/installs/ph...w=1&maxrows=12
Quick Reply: anyone have a nice low key shift light??
