Sponsored by: DashLynx
Clay Barring help?
Old 07-08-2007, 09:03 PM
Scammer Alert!
Ricks99ls1's Avatar
Default Clay Barring help?
Ok so i went ahead and bought the Meguires Gold class, now i want to know what brand i can get from Auto Zone or Pep Boys claybar that is, also how is the proper way to claybar? any help would be greatly appreciated
Old 07-08-2007, 09:06 PM
Havok2's Avatar
i would like to know as well.
Old 07-08-2007, 09:23 PM
02_LS1's Avatar
The only clay bar I have used is Zainos which you can only purchase online. I'm sure all claybars will give you the same results (dont know about that liquid claybar crap though).
Here are the instructions:
1.) Before using a Z-18 ClayBar™ on your car, you must thoroughly clean and dry your car to remove any loose dirt. Direct sunlight should not fall on your car's surface, and it's best if the work area is relatively cool to prevent rapid evaporation of the clay lubricant. Do not risk scratching your car; if you drop your clay bar, throw it away!
2.) To use Z-18 ClayBar™, you spray a water-based lubricant on a small area of your car and rub the bar back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Z-18 is fairly sticky, and cannot be used dry. If you try using it dry, you'll make a big mess. We suggest mixing one cap full of Z-7 Show Car Wash with water in a 16 ounce spray bottle. Z-6 also works as a lubricant for Z-18 ClayBar, but Z-7 Show Car Wash is much more cost effective.
3.) After a few passes with the Z-18 ClayBar™, rub your hand over the area to feel if the surface contamination was removed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft terrycloth towel, and buff to a nice luster. Just like polishing with Zaino Show Car Polish, work in small areas.
4.) Check your Z-18 ClayBar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint. If you drop your bar of clay on the ground, it's history. Toss it out. Don't take any chances, discard the clay bar if it becomes impregnated with grit.
5.) Do not overuse. A single bar will do 3-4 medium size cars with moderate contamination. If you are removing heavy overspray or rail dust, use the bar once and throw it away.
6.) When you're finished claying your car, you should wash it with Z-7 Show Car Wash to remove the lubricant film. Finally, seal your freshly cleaned paint with your choice of Z-2 Show Car Polish for Clear Coated Car Finishes, Z-3 Show Car Polish for Non-clear Coated Paint, or Z-5 Show Car Polish for Swirl Marks and Fine Scratches.
Old 07-08-2007, 10:13 PM
black97ss's Avatar
very nice write up. well said nothing to add!
Old 07-08-2007, 10:41 PM
Havok2's Avatar
Print!
Old 07-08-2007, 11:12 PM
02_LS1's Avatar
straight from Zaino's website.
Old 07-09-2007, 12:23 AM
kmgsix08's Avatar
yup that pretty much covers it
Old 07-09-2007, 12:26 AM
tylerdj's Avatar
Just make sure you keep the surface that you are claying (as well as the clay) nice and wet and please just throw the claybar away if you drop it.
Old 07-09-2007, 10:36 AM
Gipraw's Avatar
oder some online from our sponsor, Tropi-care ..
or .. if you want to pick it up locally, then grab a Meguiar's or Mother's kit .. either will work well. grab a good microfiber towel to dry the surface as you go ..
follow the instructions that come with the kit ..
tear the bar in half, and use half at a time, that way if you drop it, you don't have to run back to the store..
if you drop it, throw it away .. period ..
Old 07-09-2007, 03:50 PM
LS1TECH Sponsor
Steve P's Avatar
Need just the bar? We can accommodate you. Contact us for special unadvertised pricing at steve@tropi-care.com or call toll-free at (866)341-0050. We can do up to 3 average sized vehicles with one bar. When you can not expose a clean surface, it is time to replace with the next piece.
Old 07-09-2007, 06:17 PM
Moderator
davered00ss's Avatar
Get the meguiars clay bar kit. It's less than $20. You can get it at autoZone, advanced auto, was-mart, etc.,.
The kit comes with the spray detailer. Use a lot of it to keep the area you work lubed up. It works great. The kit comes with an awesome microfiber towel and some cleaner wax.
It's easy to do. Just rub the clay bar over the surface. Takes no time at all and the paint looks amazing after. You do have to wax it right after because the clay removes all the wax from the car.
Old 07-09-2007, 06:18 PM
Moderator
Never tried the Mothers, but it's at wal mart for $13.77.
Old 08-02-2007, 11:38 AM
willyd465's Avatar
sorry for bringing up an old post, i did a search. i have the meguires kit, do you guys use both bars that come with it or just one of them
Old 08-02-2007, 12:40 PM
Camario's Avatar
I had one little bar about 5x3 inches that came in the mothers kit and i cut it in half in case i were to drop it. i did but luckily i had another half. Maybe thats why they gave 2 bars?
Old 08-02-2007, 01:54 PM
Gipraw's Avatar
cut it in half .. you should end up with 4 pieces out of the Meg's kit.
Old 08-02-2007, 02:01 PM
GoFast908Z's Avatar
one more tip......dont' rub hard! it leaves marks similar to sanding if you do.
Gently rub across surface and you'll be fine.
Old 08-02-2007, 09:45 PM
willyd465's Avatar
thanks for the tips, plan on doing a full detail job saturday/sunday
Quick Reply: Clay Barring help?
