How To Install Clear Front Corners On A Trans Am?
Hi everyone...
I've searched here and LS1.com to find out the procedure to change the front corner lights on a Trans Am. All I can find is information on how to change them on a Camaro by removing the headlights. I'm figuring I don't want to go this route with the Trans Am pop-up headlights; I'm not removing them.
What is the easiest way to change the front side marker lights on a Trans Am?
Thanks!
Jeff
Thanks!
Jeff
Sold The Fun Stuff :(
You just take out the single torx bit screw holding each of them in, pull them out, twist the bulb out and put it in the new one, slide it in place, and put that one torx bit screw back in. If you take a look at the side markers up close it's pretty self explanatory.
are you talking about the teardrop shaped ones....like the driving lights or are you talking about the rectangular side markers. the only way i've found thats easy to get out the teardrop shaped one is to turn on the headlights, and remove the black beauty panel that goes around the lights. then look down inside the bumper and itll be very clear
