headlight removal?
I usually remove the whole L shaped bracket that holds it in place by unscrewing both screws, the one that holds the headlight to the bracket, and the one that holds the bracket to the car. It usually makes it easier to take them out and reinstall them if you screw both adjustement (aiming) screws in such a way that the headlights will aim more upwards. Before you mess with the aiming screws though, I would take some masking tape and tape it around the exposed thread as a marker, when you turn the aiming screws, more thread will be visible. Once you reinstall the headlights, just screw the aiming screws back where the tape ends.
Good luck!
Manny
Good luck!
Manny
it also helps if you take the 5 push plugs across the top of the nose and lift the nose piece up so the light will slide a bit easier and also you might wanna put some mask the paint with some tape because you will scratch it up trying to reinstall the headlight.
this should help if you havent done it already.
https://ls1tech.com/forums/showthrea...dlight+removal
