Removing window tint...HELP!
Ok...first of all I'm new to the whole idea of removing window tint and not really fond of it but I'm debating this due to the number of cops that keep eyeballing my tint. So...in turn what I'm asking you guys is what's the best way to remove the adhesive or whatever after I actually peel off the tint itself. I've heard that you can use a razorblade and some kind of solution. Using the solution isn't what bothers me...it's the fact of using a razorblade on my window...and I'm not fond of that idea...so could you guys pitch in and give me some other ideas/methods of removal???
thanks everyone
note to everyone: VA's tint law suck!
thanks everyone
how long would you say approximately it would take me to remove the tint on the 2 side windows? I don't think I'm gonna do a thing with the back...state law says it should be 35% and mine's not but 20% but I don't think they can actually get a meter on that to prove otherwise...but...if I'm mistaken someone please lemme know...I'm not 100% certain about them being able to check the back...just going from "hearsay"...thanks
yeah, Illinois tint law sucks as well, I got 4 tickets for tint. First, pull off the tint carefully, then clean up the glue with some rubbing alcohol, don't use blades they will scratch your windows, and cover the inside of your door so they don't get all wet from the alcohol.
I wasted a lot of time using "adhesive remover", but I would say an hour a window, but purely a guess
Time: Half a Day
Materials:
Warm sunny day
Tarp
Large plastic garbage bag
Undiluted Ammonia
Windex (a glass cleaner)
Paper towels
Fine steel wool
Razor blades
Tools:
Slotted Screwdrivers
Phillips Screwdrivers
Tips: The difficult thing about removing tint is that most film is constructed of two layers of tinted polyester. When you try to peel the film off the glass, the top layer will usually pull right off leaving the second layer behind. This second layer will not peel off, it will just flake and tear like a price tag.
Step 1:
To overcome separation between layers you must soften the adhesive so that both layers peel at the same time. This is very important, if you peel the just the top layer, you may as well just use razor blades as there is no way to peel the second layer off without picking at it for a few hours. You MUST try to peel both layers at once.
NOTE: You are more than likely to damage one or more of your defroster lines, when this happens, the cut line will not work anymore. Some cars have radio antennas mounted alongside the defrosters made of the same material. If you damage these, your radio antenna will not work! Be careful! Taking it to a tint shop to be done greatly increases the odds of saving the lines, but even a tint shop can not promise to save your lines, sometimes the film is just too far gone.
Step 2:
First, clear the window of any obstructions, like the brake light, speaker covers, etc.
Step 3:
Next cut open the garbage bag so that it will be big enough to cover the entire window. Spray some water on the outside of the back window and the lay plastic bag over the glass. Cut away excess plastic so that it is now roughly the same shape as the glass.
Step 4:
Next, lay a tarp over rear deck and seat, spray ammonia liberally on the inside of the back window. (Ammonia is very strong, I suggest you hold your breath during this step) and cover ammonia-soaked tint with the plastic bag so that it won't evaporate.
Step 5:
Park the car with rear window facing the sun for about an hour. The film should now be ready to peel.
Step 6:
When you are ready to start peeling, leave the plastic in place so the ammonia wont dry. Get the peeling started with a razor blade in a corner where there are no defroster lines. Try to peel film off in one piece. If the ammonia dries as you peel, the glue will get hard again, so spray a bit of ammonia on the area as you peel.
Step 7:
Once the film is peeled, you will need to scrub the adhesive off with ammonia and fine 0000 steel wool. Mop up scrubbed areas with paper towels before they dry. Finish up with window cleaner and paper towels.
Step 8:
Removing tint from side windows Soaking is not nessesary here. You may want to use a simple razorblade holder. Cut a notch onto the upper area of the film so that you have a piece to pull. Try to peel the film, it will probably come off in two or three pieces.
Step 9:
Spray the remaining adhesive with soapy water, and scrape the adhesive off with a razor blade, avoiding the edges of the glass to keep the blade sharp. You may need to use a few blades as they dull quickly.
Step 10:
Finish up with window cleaner and paper towels. Inspect for missed glue (it's clear and hard to see).
This helpful article was provided by DoItYourself.com community member Ric Nelson.
There is one method. I am going to try to steam my windows. I conviently have a wallpaper steamer at my disposal, but here is a neat write up using a simple clothing steamer.
http://www.instructables.com/id/E2VW0SBUA5EXCFDGDM/
Materials:
Warm sunny day
Tarp
Undiluted Ammonia
Paper towels
Fine steel wool
Razor blades
Tools:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Step 9:
Step 10:
