Painting The Engine Bay..
ok i just did the wire mod and plan on doing the latch mod this weekend and i was wondering if anyone has a quick write up on how to paint the engine bay.. i have a white cam with a black top ill post pics of the engine bay thanks in advance...
https://ls1tech.com/forums/showthrea...nt#post6125512
There are some pictures of mine and a quick write-up
I sanded mine down with 800 grit. rattle can sandable primer black. sanded it again with 1000. and then did two coats of low gloss black in a rattle can. It came out very nicely. Of course touch up is simple!
As long as you use a low gloss or flat color, rattle can is fine. I would have been nervous and probably used more steps with a gloss finish.
